Results 1 to 10 of 21
Thread: Mega Tree
    May 2008
    Allen, TX
    190
    Default Mega Tree
    Could you share guys infor about mega tree for beginner.
    I'm thinking ~10 feet 16 channels tree.
    How to build it cheapest - strong way.
    Do anybody try kits from here
    http://christmaslightshow.com/xcart/...hp?productid=4
    or here
    http://www.wowlights.com/ProductDeta...20&Product=183
    Are they worth money?
    any suggestions welcome ;)
    [B]2009[/B] 88 channels (add SS24), 10.000 lights, 2 collor megatree, 12 mini trees, C9, floods
    [B]2008[/B] 64 channels (grinch+ren-c), 8.000 lights 12ft megatree
    [URL="http://www.christmasinallen.com"]http://www.ChristmasInAllen.com[/URL] for photo,video and how to DIYC
    Lawrenceville, GA
    69
    Default Re: Mega Tree
    Here is a link to a great tutorial on the mega tree - http://www.landolights.com/main/content/view/80/39/
    Hope this helps.
    Thomas
    North Ridgeville, Ohio
    1,558
    That is a nice tutorial. I like the idea of putting the upside-down screws on the top to keep the birds from perching, so you don't end up with a mega bird potty.
    Who's site is that? Is it someone here?
    Don
    Mechanicsville, VA
    1,072
    My mega tree will be 18 feet tall (give or take a foot)
    24 channels with one set of string per channel. It will be 5 colors (gold, white, blue, red and green) and have a 3.5 foot wide star at the top. I am using support wires in the middle of the tree (at the 10 foot joint) and then off of the star at the top. 2" EMT tubing/conduit is the center for my tree. 1/2" plastic conduit will the the base that will be anchored 6" or so off the ground (just to keep the plugs completly off the ground)
    Ben
    128 lynx Freestyle DMX channels(not all used), 4 SSR4 DMX channels, 120 Ren24 channels, and 48 Ren16 channels!!
    Jul 2007
    Curtice Ohio
    258
    Mine is about 12 ft tall. Used 25 ft lights and stringed them up then back down, 3 colors, 48 channels. You can see how mine was made here
    http://www.trumbullchristmas.com/construction.aspx
    (finally organized the site a little better)
    The one thing I will do different this year is get the base off the ground. The only reason is the snow covered more of the base than I thought it would. The only time I ever tripped a GFCI was during an ice storm. I never had any issues with power under the snow.
    centereach ny
    173
    i have the 14 foot version tree from christmaslightshow.com and the tree is awsome it only took me a couple of hours to build and set it up. its has somewhere around 5200 lights and will be controlled by 19 channels. 16 for the tree and 3 for the 3-d star. i set it up and painted it the day before i put the lights on. the only thing i would suggest if you choose this one is to use krylon paint for plastic because i used the cheap walmart paint and it chipped and when the lights hit it it got all scrapped up and the white pvc showed.
    just my 2 cents
    danny
    Danny Smith
    2008 display:
    -168 renard 24 channels
    -fm transmitter: ramsey 25B
    -light count: 15,000+
    [CENTER]The thing always happens that you really believe in; and the belief in a thing makes it happen.[/CENTER]
    May 2008
    Allen, TX
    190
    After reading around I decide to build 10 feet tree using PVC pipe. What size of pipe you guys are using? I saw in some pages 2' and 1 1/2' inside ? Will it gives more strength ? What is advantages/disadvantage to use 40 or 80 pipe ? I read that 80 has thicker walls, so maybe it holds better against bending ? What other concerns I should take in mind ?
    Jul 2007
    Under the bed...
    546
    I used 2" black ABS last year and at 12' it was barely standing straight. Out here in California we can still get warm days in December. And what would happen is one side of the ABS pipe would warm in the sun and the top of the mega would warp and start to tip over. I think if I had had a few more strands of lights up there it probably would have toppled or collapsed. PVC is even more flexy than ABS. So I dunno. The 1-1/2 inside the 2" may not be a bad way to go. But I think If I put up the mega this year, it will be 3 or 4" ABS
    Even Twitter has 140
    Galt, CA
    520
    Last year I used a 2" x 10' PVC pipe for my mega tree. I connected guy wires to the top and middle of the PVC pipe down to the ground. The middle guy wires seemed to provide stability to keep the pipe from flexing.
    May 2008
    Allen, TX
    190
    Quote Originally Posted by XmasInGalt View Post
    At what height approximately you connect middle guy wires ? 5' ?
