Go Back   Do It Yourself Christmas Forums > Learning center > Cutouts and Wireframes
Cutouts and Wireframes Plywood and Coroplast cutouts and Wireframes
Reply
Thread Tools Display Modes
  #1
Old 11-21-2008, 11:37 PM
Rocketman4 Rocketman4 is offline
Member
Default Tomato cage - Snowflake
How to make a Snow flake out of 2 Tomato cages. The cages need to be the type with only 3 legs. First cut the rings in the center of each leg. Flatten each section (3). Next bend the flatten ring wire approx. 30 degrees. You now have six sections that can be easily joined together with electrical tape. I prefere white hence a snow flakes natural color. The bottom or larger section is over lapped as shown in the picture. Tape each leg at the vertex. You should be taping three pieces of wire together. Two short sections and one long leg section. You now have a snowflake frame that can be wrapped in lights. Cages can be found at Lowe's for less than $2.
__________________
Youth is wasted on ignorance. Any information posted by Rocketman4 should be used with great caution and he isn't Liable for any damage caused by YOU. Rocketman4 reccomends that a qualified Electrician inspects your display before illuminating.
  #2
Old 11-21-2008, 11:55 PM
omzig's Avatar
omzig omzig is offline
Supporting Member
Default Re: Tomato cage - Snowflake
Yet another use for tomato cages! Did you know that some people use them to grow tomatoes?
Very nice! I may add this to my list for next year. Thanks for sharing.
__________________
Don
  #3
Old 11-22-2008, 12:45 PM
WWNF911 WWNF911 is offline
Member
Talking Re: Tomato cage - Snowflake
Quote:
Originally Posted by omzig View Post
did you know that some people use them to grow tomatoes?
r o f l
  #4
Old 11-22-2008, 01:04 PM
Virtus Virtus is offline
Member
I must be growing domesticated or free-range tomatoes...never needed to cage them!
  #5
Old 11-22-2008, 01:41 PM
Macrosill's Avatar
Macrosill Macrosill is offline
Administrator
Wow, neat idea!
__________________
www.christmasinshirley.com
www.DoItYourselfChristmas.com
Running an AMD Athlon 64 3000 1.8 ghz, 1 gb ram, Nvidia GForce 6600GT video card with 128mb ram, Soundblaster Live audio card, 2 serial port pci expansion card, Windows XP Home SP2
  #6
Old 11-22-2008, 09:34 PM
joneslights joneslights is offline
Member
Does it have to be a 60 degree angle, or will a 62 degree angle work?
__________________
"Think you might be over doing it dad?" "When was the last time I over did anything?"
http://www.joneslights.com/
  #7
Old 11-22-2008, 09:42 PM
Dino242's Avatar
Dino242 Dino242 is offline
Supporting Member
Quote:
I think the snow melts above 60 degrees
__________________
2007: Staic Display
2008: 15000+ Lights, 128 Dimming Channels
2009: 31000+ Lights, 400 Dimming Channels
2010: Ahhhh.. I worry about that later
www.christmasonthebayou.com
  #8
Old 11-23-2008, 12:18 AM
Flash69 Flash69 is offline
Member
I guess I should try to make time to wrap the snowflake in white electrical tape and post pictures?
Rocketman made "the original" Snowflake for his brother-in-law, me.
  #9
Old 11-23-2008, 11:56 AM
phenagan phenagan is offline
Member
Has to be 60 to for everything to line up (6 * 60 = 360 degrees = a full circle)
  #10
Old 11-23-2008, 12:37 PM
Member
Quote:
I knew there was a reason.
__________________
Reply
Tags
snowflakes
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
