Go Back   Do It Yourself Christmas Forums > Hardware > Other Hardware
Other Hardware Anything that doesn't fit in the above
Reply
Thread Tools Display Modes
  #1
Old 10-11-2007, 03:15 AM
wjohn's Avatar
wjohn wjohn is online now
Supporting Member
DIYC Moderator
Default FM Transmitter
Hi,
I decided to buy a FM transmitter from China, in preference to using a Belkin or another IPOD style transmitter. The unit I purchased off ebay was rated at 200 mW, and has the follow specs:
Frequency range: 87.5MHz ~ 108 MHz
Tuning Step: 100kHz
Transmit Power: 200 mwatts(Cover about 150 meters)
Stability of Frequency: ±10ppm?-10?~+50??
Ripple or harmonic waves: <= -60dB
Modulate Frequency error:<=75KHz?100%?
Freq. Response: 100~15000Hz
Antenna Connector: SIP
Audio Input Connector: SIP
Power Supply: 12V DC (The current load of power supply should over 2A)
I trialed the FM transmitter today, and with 2 metres of light hookup wire, taped to my study wall, I was still able to hear my music 800 Metres away (about 2 blocks). Clear Line Of Site improved reception as I noted I lost coverage as I droven down in a gully, and improved as I came out of the low area.
the Shipping is a bit expensive, but for speed and function, I highly recommend. (maybe go in with a couple of buyers and split the costs).
http://cgi.ebay.com.au/eBayISAPI.dll...m=230179871880
John.
  #2
Old 10-11-2007, 08:00 AM
greenmeanie greenmeanie is offline
Member
Default
Nice and small compared to the Ramsey.
  #3
Old 10-11-2007, 09:23 AM
FireGod's Avatar
FireGod FireGod is offline
Member
DIYC Moderator
Default
It looks like a good deal! How much was shipping? I assume is is PLL enabled? The Ramsey FM25B is $140 unassembled.
I feel like two blocks is plenty of range for our purposes.
  #4
Old 10-11-2007, 10:00 AM
stempile stempile is offline
Member
Default
$30 US Shipping. Looks interesting! Cheaper then the kits I got last year!! and especially if you throw in the cost of the Tuncast I went with anyway...
US Ebay Link
ms
__________________
Matt Stemple
  #5
Old 10-11-2007, 10:12 AM
sigtaulightning sigtaulightning is offline
Member
Default
If a group shipping rate can be found I would probably go in on one.
__________________
RoB
  #6
Old 10-11-2007, 10:36 AM
grages grages is offline
Member
Default
I too would be interested if a group could be put together.
Is that the only shipping choice? At the bottom of the blue area there is a another shipping type
Quote:
Flat international shipment via air mail 8-10 business days $20
__________________
"A polar bear is just a rectangular bear after a coordinate transform"
http://www.christmasinshirley.com/fo...inch64_128.jpghttp://www.christmasinshirley.com/fo...logosm_202.gif
  #7
Old 10-11-2007, 11:27 AM
Member
Default
I have emailed them to see if we can get a multi piece discount for shipping. I will let you know. If it all works out I dont mind placing the order and then distributing them once they arrive. They seem to be fairly small so shipping should not be very much.
__________________
RoB
  #8
Old 10-11-2007, 11:36 AM
scharbon scharbon is offline
Member
Default
If you can get the mass shipment, I will buy one also. Thanks
Steve
  #9
Old 10-11-2007, 11:40 AM
Josh Josh is offline
Member
Default
they also sell a 1W transmitter, its 40 shipping and around 25 on the bids http://cgi.ebay.com.au/1-0Watt-FM-Ra...QQcmdZViewItem
  #10
Old 10-11-2007, 05:46 PM
Wayne J's Avatar
Wayne J Wayne J is offline
Member
Global Moderator
Default
A group buy may be better direct. (if you can buy from them and read the page. )
http://www.vastelec.com/jpxl.htm
__________________
http://jamesfamilychristmas.com/
Lighting up Mooresville with 500+ channels
Watch for the 2010 Downtown premier
Reply
Tags
transmitters
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
