Revision as of 17:03, 24 June 2013 by Jklingert (talk | contribs) (Tee)
Generally pixels come from vendors without connectors attached or they have proprietary non waterproof connectors connected to them. Most people utilize some form of water resistant connectors attached to their pixels and the mating connector to their pixel controllers. It is common to install the female connector (socket end) to the power source (controller) and the male connector( plug end) to the pixel string. Some people also use dielectric grease or protective spray like CorrosionX to further prevent corrsion and oxidation of the electrical contacts due to moisture.
Connectors from different vendors generally do not fit together due to different manufacturers sizes and keying.
Types of Pixel Connectors
Euro Connector
These connectors are typically found on pixel controllers like the Sandevices E682 of the Renard PX1. They are polarized and the plug only fits in the socket one way.
Euro Female socket
Because the plug and socket are polarized it is critical that you connect the wires correctly to the controller and the pixels. The wire order for the typical E682 pixel controller is:
E682 Pixel Output Pin Assignments
Pin #
Signal
1 GND (V-)
2 Clock (C)
3 Data (D)
4 V+
Euro Male Plug
The male plug is generally attached directly to the pixels or may be connected to a pigtail. They can also be purchased from Mouser in two versions, one with an inline wire entry like used on the Sandevices E682 and one with a rear wire entry as used on the Renard PX1
Pigtails
These are typically connected to the end of the pixel strings .
Tee
Often used for power injection. Depending on the vendor, they may have all wires connected thru to all three jacks, or some may have only some wires connected.
Extension cable
Caps
These typically go on unused female pigtail ends to seal them from the weather.
Wire Sizing
It is desirable to use the largest wire diameter (smaller wire gauge) that you can when connecting your pixels to your controller. The smaller wire gauge results in a high voltage drop and can cause your pixels to have poor colors or to not function at all. This is a good thread that discusses voltage drop. This is a Voltage Drop Calculator useful for calculating the effects of different wire sizes and lengths on pixel strings.
Wire Sizing
Wire Gauge (AWG) #
Cross section Area (mm2)
14 2.08
16 1.31
18 0.823
20 0.518
22 0.328
These are selected connectors from the various vendors with a mix of properties. Visit their sites for the latest information and to see their entire product catalog. Many of the vendors can provide custom length wires on the pigtails.
Ray Wu
(China Based)
Type Color Conductors Length Diameter Link Image Quantity Price Price per Connector Note
Cap White 13.5mm link 10 $0.50 $0.05 End cap to go on unused male plugs
Cap Black 13.5mm link 10 $0.50 $0.05 End cap to go on unused male plugs
Pigtail White 2 20cm 13.5mm link 10 $3.00 $0.30 2x0.5mm²wire
Pigtail Black 2 15cm link 50 $23.16 $0.46
Pigtail Clear 2 10cm link 100 $57.89 $0.58 Coaxial 5.5/2.1mm 22gauge wire
Extension White 2 1.5m(5feet) link 10 $10.00 $1.00 2x0.5mm² wire
Extension White 2 3m(10feet) link 10 $16.00 $1.60 2x0.5mm² wire
Tee White 2 40cm 13.5mm link 10 $17.00 $1.70 2x0.5mm² wire
Tee Black 2 40cm 15mm link 1 $2.20 $2.20 2x0.75mm² wire
