ESPixel Stick & ESPixel Pops
Version V2
Version V2
Version V2
Version V2
Version V2
Version V2
What is a Pixel Stick?
Pixel Pops & Tiny
Pops-O-Matic Info
small
small
Order your own boards
If ukewarrior is out of boards, you can order them in groups of 3 from OSHPark: Click here for the Ordering link at OSHPark to order your own boards
These are available for a total of 34 cents from Tayda Electronics.
Fuse Holder
5A Fuse
Version V2
The BOM's are:
Mouser BOM is in Post #35
Arrow BOM is in Post #48
Digikey BOM is in Post #49
small
small
Wiring The ESPixel Pops
small
small
small
small
A Key Point Regarding Power
Programming the ESP-01 Module
As of 11/21/2019, the current release by Shelby that implements dimming control and other features.
Version 3.1 is a Major Update Many features including direct support of Webmos & NodeMCU ESP modules. You can find it here: https://github.com/forkineye/ESPixelStick/releases Pixel Stick Software]
Upload the firmware
Download the latest Firmware.
Install Java JRE.
