SSRneon-led
Version G2
Version G2
Safety Features
ne-2E
ne-2E
1. Dual Neon bulbs that indicate the presence of AC Voltage !
terminal block
terminal block
heat sink
heat sink
TA-200
TA-200
Order your own boards
Home Etch
copper
copper
Fuse Rating
fuse
fuse
BOM for 120VAC Operation:
4      571-1-390261-1     IC Sockets 6P ECONOMY TIN  (Optional, but worth every penny)
                          also marked U1, U2, U3 and U4
5      571-2828372        Terminal Blocks 5.08MM PCB MOUNT 2P
See above for TA-200 sources.
240VAC Operation
FireGod
Version G2
Version G2
This PCB has a different terminal block ------------------------------------>
Wiring The SSRneon
Controller Output Pinout
Pin Number Connection
1 +5v DC Power
2 Channel 1 Signal
3 reserved
4 Channel 2 Signal
5 reserved
6 Channel 3 Signal
7 Ground
8 Channel 4 Signal
Version G2
Version G2
Original SSRneon
