Search results
  • *[http://www.doityourselfchristmas.com/wiki/index.php?title=DirkCheapSSR Dirknerkle's Low cost ACSSR (DirkCheap)] ...
    4 KB (585 words) - 21:32, 8 August 2013
  • ...verts a wired Renard controller into a wireless controller. (pcb design by Dirknerkle. See [http://www.diychristmas.org DIYChristmas.org]) ...on the SS16 but designed for external SSRs and is wireless. (pcb design by Dirknerkle. See [http://www.diychristmas.org DIYChristmas.org]) ...
    6 KB (810 words) - 12:16, 18 May 2014
  • ||[http://www.doityourselfchristmas.com/forums/private.php?do=newpm&u=3044 dirknerkle] ...
    11 KB (1,466 words) - 17:25, 26 July 2013
  • <br> Contact <br> dirknerkle ...
    7 KB (1,019 words) - 21:42, 28 November 2013
  • ...rmware runs Renard protocol and is setup with start addressing to run with dirknerkle's RenW wireless boards. A DMX version is currently being tested and should ...
    24 KB (4,144 words) - 21:36, 31 May 2013
  • ...act [http://doityourselfchristmas.com/forums/member.php?3044-dirknerkle '''dirknerkle'''] for pre-made boards) ...to the Express PCB source file for the STANDARD board: [http://digwdf.com/dirknerkle/pcb/ren-w-master.pcb Ren-W STD PCB file] ...
    17 KB (3,006 words) - 16:40, 23 June 2015
  • ...ne controller working at a time, and you’ll work through them. However, '''dirknerkle''' authored this document, so try him first. '''That said, if your question ...
    24 KB (3,877 words) - 20:30, 6 December 2021
  • You can always send your Ren-W boards to Dirknerkle -- he'll be glad to check them out and fix whatever needs fixing. If you ne ...
    20 KB (3,384 words) - 01:21, 2 July 2012
