Search results
- ...based on the PIC-based 8-port dimmer concept originally developed by Phil Short. Information on the original concept can be viewed [http://computerchristma ...5 KB (801 words) - 13:46, 9 March 2013
- ...based on the PIC-based 8-port dimmer concept originally developed by Phil Short. Information on the original concept can be viewed [http://computerchristma ...layout is in the power cables. Most of the channel power cables are very short. This system is very good for widely spaced display items with small group ...16 KB (2,463 words) - 02:19, 11 July 2013
- ...based on the PIC-based 8-port dimmer concept originally developed by Phil Short. Information on the original concept can be viewed [http://computerchristm ...12 KB (1,881 words) - 17:16, 26 July 2013
- ...h] and [http://doityourselfchristmas.com/forums/member.php?9-P.-Short Phil Short]. They are available from [http://www.diyledexpress.com/index.php?main_page ...You need to solder eight jumpers through these holes to each of the PCBs. Short lengths or wire or cutoff leads from resistors or other components work gre ...23 KB (3,897 words) - 14:19, 3 August 2013
- ...based on the PIC-based 8-port dimmer concept originally developed by Phil Short. Information on the original concept can be viewed [http://computerchristma ...15 KB (2,365 words) - 03:42, 2 November 2013
- ...based on the PIC-based 8-port dimmer concept originally developed by Phil Short. Information on the original concept can be viewed [http://computerchristma ...17 KB (2,714 words) - 23:12, 10 May 2017
- ...based on the PIC-based 8-port dimmer concept originally developed by Phil Short. Information on the original concept can be viewed [http://computerchristma ...17 KB (2,721 words) - 23:14, 10 May 2017
- ...f controllers so much of the credit goes to Wayne James and of course Phil Short for their contributions. The output section is taken from the Ren48LSD but Configure a short Vixen sequence with a slow on/off sequence for each channel - 1 second on, ...26 KB (4,577 words) - 02:58, 2 June 2015
- ...based on the PIC-based 8-port dimmer concept originally developed by Phil Short. Information on the original concept can be viewed [http://computerchristma ...27 KB (4,113 words) - 18:27, 9 July 2014
- ...ki.vixenlights.com/tiki-index.php?page=LEDtriks+controller written by Phil Short. ...17 KB (2,943 words) - 02:30, 18 August 2011
- ...gned by [http://doityourselfchristmas.com/forums/member.php?9-P-Short Phil Short] as an inexpensive Pixel controller designed to work with standard Renard s #<span style="font-size:21px">□</span> Install Headers. '''The short end of the header is soldered into the PCB.''' ...39 KB (6,334 words) - 15:14, 23 February 2022
- ...gned by [http://doityourselfchristmas.com/forums/member.php?9-P-Short Phil Short] as an inexpensive Pixel controller designed to work with standard Renard s ...36 KB (4,823 words) - 19:19, 4 June 2022
