whitechristmas25
Supporting Member
Hello all!
I'm currently in the process of trying to get some Wifi OneBangers to work and am not understanding the communication path. Any guidance is greatly appreciated!!
For reference
Would it be possible to guide my through how the pieces are supposed to communicate?
Thank you!!
For reference
- FPP 7.3.1
- Vixen 3.12u3
- Have successfully run a Renard TR-16 (wired to serial on the RPi)
- Desired Renard Channels for OneBangers (33, 34, 35)
- Wifi OneBanger - Connected to same network as FPP, able to ping and change settings via web
- Wifi OneBanger '34' is the unit I'm testing and has PIC 16F1825 is flashed with Renard 1825 firmware (address 4) -
- My assumption is that this channel number needs to match Vixen, and Address Firmware '4' should have the start address at 33.
- I also only have Addr firmware from 1-36
- Jumpers connect PIC pins V+ and 'Channel '1' to AC pins V+ and 'A'
- Question - If this is 'channel 34' - should I have the PIC pin at '2' instead (and match accordingly for the other OneBangers?)
- ESPixel Output is jumpered to 'GPIO2' as I'm using ESPixelStick V3.2
- FPP has E1.31 Output enabled with
- Source: eth0, Output Count 2
- Unicast 1 and 2 - IP addresses .33 and .34
- FPP Start Channel 1 / End Channel 1 / Universe Count 1 / Universe Size 1/ Universe Priority 0 [Edited to include this]
- Vixen has Renard #1 (Channels 1-16), Renard #2 (Channels 17-32), then Individual Streaming ACN E1.31 for each OneBanger
- The Steaming Devices are set to Start 1 / Universe 1 / Size 1 with destinations as Unicast and IP addresses set to match respective channel numbers ( on the same VLAN - .33, .34 and .35) - This was more of a convenience consideration
- Exporting my 'test' FPP sequence shows alignment with the Quantity/Start/End channels (Renard #1 - 1 thru 16, etc.)
- I'm tryin to test OneBanger '34' is set with
- Universe 1 / Start Channel 1 / Universe Boundary 1
- Serial Config with Channel Count '1' / Protocol 'Renard' / and Baud Rate at '57600'
Thank you!!
