Loose Pixel in coro solution?
JaxLax
New member
I've got some new Hatitude Quartets and using Evo Domes in them and there just isn't any friction between the two items to securely hold the pixels in place. If I pick it up vertically; a few tend to fall out.
Is there any easy fix for this or am I just going to have to be extra careful and vigilant when installing and during the show if any fall out the back?
I thought about running a paint roller across the back to get everything somewhat flat and then either using some painters tape in a grid or using some Press'n'Seal rolled on? Just need a little something to hold them down, but not so much that any repairs or replacements will damage/ruin the prop.
Thanks for any ideas.
I won a prop at a Mini that I think was drilled sightly too big for the bullets I was using. I found some thin clear washers on Amazon that I put on the front size to hold them on. That was three years ago. I wouldn't doubt that someone sells sleeves that fit in the hole to shrink it a bit.
That's gonna be a lot of dabs...
697 pixels for 3 props - 2091 dabs. Guess I'll look at the bulk packs of glue sticks on amazon
I once filled each cell in a 2'x4' ceiling grate with a pixel in each cell. Actually not that bad. Did the same for my 5 arches with 200 pixels each. It is the refresh at 5 years that got to me.
I had the same issue with a piece of coro, I ended up just using filament to "lock" in the pixels, I popped a pixel in along with filament at the same time then cut the filament some of the bigger holes I needed 2 pieces of filament.
Shawn
Back
Top
