Thank you Ernie. I was able to download the manuals.I don't know anything about the Express boards but It looks like the old files are hosted here. https://zappedmyself.com/projects/dla/
Is it just one bad channel? Does the channel indicator LED come on?I took some pictures of both sides of the board and Claude analyzed the pics, and put together some points for me to test with. Currently I have 1.4 VDC to pins 1 and 2 on the MOC3023 but nothing on the AC side. I have replaced the TRIAC already so I am thinking I have a broken trace or a bad resistor.
I will reach out to the Admin and see if I can get the docs.
I found the problem. I had lifted a trace accidently when removing the Triac. All good now.wow, crazy that site went down. It used to be so active...
Google found the document in the wiki here on this site, but the wiki has been disabled. Perhaps an admin can retrieve it and get it to you?
Otherwise I use Lynx Express and can try to help (although I don't believe I have the manual saved off)
