madsci1016
New member
Hello all. This is a information thread on the RenardESP WiFi adapter. The development thread can be found here.
What does it do?
The RenardESP adapter will convert any Renard that uses the SS BOM (and most of the non - SS models) from a device controlled by RS-485 Serial to a device controlled by e1.31 or sACN over WiFi. It does this by replacing the RS-485 receiver chip on the Renard board.
So instead of running CAT 5 through your yard and connecting your Renards to a RS-485 USB adapter or an e1.31 bridge, you can cut the cords and stream all your control data over wifi. Here's an illustration:
You can continue to daisy chain Renards off the first one with the WiFi adapter, or you can install an adapter in all your Renards to go 'completely wireless'.
Installation is fairly easy. You just remove the 8 pin DIP receiver chip, and replace it with a ribbon cable adapter.
I'll have updated build instructions up shortly on my website here. There should be a group buy starting soon. In the mean time, please use this thread to ask questions and I'll update this post as needed.
What does it do?
