USB to DMX adapter
I only asked about the manual because it is used to during the process of creating an Intelligent Fixture in Vixen 3.
There is a feature to upgrade sequences from Vixen 2.x to 3. It has been a long time since I used it but you define a mapping between the items in Vixen 2 and the items in Vixen 3. I believe Martin Mueller who is on this thread may have authored the feature.
Do you have a good manual that describes the channels for your moving head?
Wow that feature was done a long time ago. It all depends on a mapping table you create at the time of import. What you first want to do is lay out your show in Vixen 3, do a test sequence to make sure your preview is working properly, then import your older sequences. As you do the first import, you will create a map to go from the V2 channels to the V3 channels. It translates all of the V2 values to V3 Level and / or pulse effects. They look messy on the sequence screen, but they work.
Back
Top
