Hey all! Ive been working on this project for the past year, and Ive finally settled on a software and hardware package that can rival some of the more expensive Art-Net and sACN controllers. With a hardware revision that now supports resettable fuses, variable input voltage, hot-swappable plugs, and reverse polarity protection, I am more than confident that the node will appeal to LED-strip enthusiasts out there! For the non-professional, tinkerer, DIY geek or Christmas nerd, this node is a game-changer!
So, in short, what does it do?
- 16 universes over 4 outputs, so 2700+ RGB LEDs in total!
- Support for WS2812 type (800khz) and SPI-driven LEDs (SK9822, apa102), so basically any LED type on the market!
- RGB, RGBW, and RGBAW colour arrangement support
- Ethernet and wifi capable
- Fused Integrated power distribution up to 5A per output and 20A total
- With a 5~24v variable input, this means almost 500W of power!
- OLED display for status updates
- Hardware button to change between different modes (DHCP, Static IP, Static colour, Test pattern)
- But, most importantly, completely open source! Every piece of the software and hardware design is available for you to tinker with!
Now, if you are excited, check out the GitHub! GitHub - mdethmers/ESP32-Artnet-Node-receiver: ESP32 based artnet node to push 16 universes of LED pixels at 40fps · GitHub
Want to get a working node in your hands? Check out my shop! https://www.etsy.com/nl/listing/1890697316/artnet-led-controller-diy-kit-bedien
