Renard PX1 Pixel Controller
Revision as of 16:55, 30 May 2013 by Jklingert (talk | contribs)
General
Features
  • Standard Renard connections
  • 5VDC and 12VDC operation
  • WS2801 and WS2811 pixels
  • Some Design Details:
  1. One output (same 3.5mm connector and pinout as jstjohnz's controller), handling up to 200 pixels
  2. RS485 input, same RJ45 pinout and protocol as Renard controllers
  3. 115200 input baudrate (lower rates provided, but not recommended)
  4. Uses PIC16 parts, so existing programmers should work.
  5. Supports WS2811 strings at with either 400KHz or 800 KHz data rate, 5V or 12V power input
  6. Uses external 5V supply (readily available from Ebay, China, etc).
  7. Power, RxD and FE (framing error) indicators
  8. Jumper to select pixel speed (400 KHz vs 800 KHz)
Number of Channels (*)
Baud Rate Refresh Interval
100 ms 50 ms 25 ms
460800* 1528 764 382
230400* 764 382 191
115200 382 191 95
57600 191 95 47
38400 127 63 31
19200 63 31 15
PCB Layout
BOM - Bill Of Materials
PartMouser PNDescriptionQtyOptional
R1291-120-RCCarbon Film Resistors - Through Hole 120ohms 0.051
R2.R3299-1K-RCCarbon Film Resistors - Through Hole 1Kohms 5%2
R4,R5299-27K-RCCarbon Film Resistors - Through Hole 27Kohms 0.052
R6264-680-RCResistor Network, 680 Ohm, Bussed, 6-pin1
R7,R8299-47-RCCarbon Film Resistors - Through Hole 47ohms 0.052
C1810-FK28X5R1C105KMultilayer Ceramic Capacitors MLCC - Leaded 1.0uF 16volts X5R +/-10%1
C2,C380-C322C104K5RMultilayer Ceramic Capacitors (MLCC) - Leaded 50volts 0.1uF 10% X7R2
D3,D5604-WP710A10ITLED, 3mm Red2
D4,D6604-WP710A10GTLED, 3mm Green2
IC3926-2950CZ-5.0/NOPBLDO 5.0/100mA 1****
J1,J2571-5556416-1Jack, Modular RJ45 PCB Mount Top Entry2
J3,J5,J7.J9538-22-03-2021Headers & Wire Housings VERT PCB HDR 2P TIN PLATING4
J4649-77313-122-10LFHeaders & Wire Housings 10P STR DR TMT HDR .76 AU .526IN LENGTH1
J6538-22-03-2061Headers & Wire Housings VERT PCB HDR 6P TIN PLATING1
J8538-22-03-2031Headers & Wire Housings VERT PCB HDR 3P TIN PLATING3
J9571-2828372Fixed Terminal Blocks 5.08MM PCB MOUNT 2P1
J10538-39501-6004Pluggable Terminal Blocks 3.5MM EURO HEADER VE HEADER VERT GRN 4CKT1
Assembly Instructions
  2. Configure Jumpers
  3. Program PIC
  2. Install Resistors
    5. R4 - 680 ohm bussed resistor. Note that this resistor is polarized and only can go in one way. The dot on the package denotes pin1.
  3. Install Capacitors
  4. Install Diodes
  5. Instal IC Sockets
      The notch faces right.
      The Notch faces right.
  6. Install LEDs
    1. D3,D4 - Red LED. LEDs are polarized and they have to be installed with the correct orientation. The anode side of the LED with the longer leg goes in the top round hole.
    1. J4 - 2 pin header.
    2. J1, J7 - 3 pin header.
    3. J2 - 6 pin header.
    4. J3 - 2x5 (10) pin header.
  8. Install Voltage Regulator
    1. IC3 - LP2950CZ-5.0/NOPB voltage regulator. The voltage regulator is polarized and it has to be installed with the correct orientation. Install in location U3 with the flatside of the regulator facing the top of the board and mmatching the orientation on the silkscreen.
  9. Install Fuse Holder
    1. Fuse holder.
  10. Install Connectors
  11. Install RJ45 Jacks
  12. Install Fuse
    1. Install 5A fuse.
  13. Install ICs
Configure Jumpers
Install a jumper across Pin 1 and Pin2 if you are using RS232 Input to the controller. Install a jumper across Pins 2 and Pin 3 if you are using regular RS485 input.
J3- 2x5 Options Connector
J4- Programing?
J7- 5VDC Regulator Bypass
This 3 pin jumper is used to select the power source of the control circuit on the board. If the power input to the board is 12VDC, then jumper must be placed on the two left pins. If the power input to the board is 5VDC, then the jumper must be placed on the right two pins.
Program PIC
Connections
RJ45 Pin Assignments
Pin # RJ45 Connector
J5 Input J6 Output
1,2 GND GND
3 NC NC
4 Data- (Rx) Data- (Tx)
5* Data+ (Rx) Data+ (Tx)
6,7,8 NC NC
*This pin is connected to GND through J5 if a shunt is installed in J5.
J2-ICSP Programming Header
J2 is the 6 pin header located in the top center of the board. J2 allows the PIC microprocessor to be programmed in place on the board by directly connecting a PICKIT2 or PICKIT3 programer.
Pin 1 is the square hole towards the left side of the board closest to D1.
J2 ICSP Pin Assignments
Pin #
Signal
1 VPP/MCLR
2 VDD Target
3 VSS (Ground)
4 ICSPDAT/PGD
5 ICSPCLK/PGC
6 N/C
J8-Pixel Power Input
J8 is the 2 pin terminal block located at the bottom center of the PCB. The Renard PX1 can be powered by either 5 or 12VDC (depending on pixel type). If you are using 5VDC, you can omit the voltage regulator and set Jumper J7 to the 5v position.If you are using 12VDC, then you must use the on board voltage regulator and set Jumper J7 to the 12v position.
J8 Power Input
Pin #
Voltage
1 (square pad on left) GND
2 (round pad on right) V+
J9(4 pin)- Output to Pixels
J9 Pixel Output Pin Assignments
Pin #
Signal
1 GND
2 Clock
3 Data
4 V+
Indicator LEDs
Attn
Rx
FE
Pwr
Enclosure
TA-200
Initial Thread
