Renard PX1 Pixel Controller
General
The Renard PX1 was designed by Phil Short as an inexpensive Pixel controller designed to work with standard Renard systems. It can be daisy chained with other Renard controllers.
The design consists of a controller board with a PIC16F1825PIC microcotroller that connects via a simple RS485 connection protocollike all Renard controllers. The PX1 Controller is capable of driving up to 200 pixels per controller (with power injection after the 50 pixel) or 50 pixels directly. It supports both 12VDC and 5VDC pixels. The PX1 Controller is designed to support pixels that use the WS2811 and WS2801 IC.
Features
- Some Design Details:
- Supports up to 50 pixels from the onboard power connection
- Uses PIC16 F1825 microprocessor, so it can be programed with traditional PICKIT 2 or PICKIT 3 programmers.
- Supports WS2811 strings at with either 400KHz or 800 KHz data rate
- Power, RxD (recieving data), FE (framing error)and Attn LED status indicators
| 100 ms | 50 ms | 25 ms | |
| 230400* | 764 | 382 | 191 |
| 115200 | 382 | 191 | 95 |
| 57600 | 191 | 95 | 47 |
| 38400 | 127 | 63 | 31 |
| 19200 | 63 | 31 | 15 |
PCB Layout
BOM - Bill Of Materials
| R4 | 264-680-RC | Resistor Network, 680 Ohm, Bussed, 6-pin | 1 |
| D3,D4 | 604-WP710A10IT | LED, 3mm Red | 2 |
Assembly Instructions
- Configure Jumpers
- □ Install Resistors
- □ R4 - 680 ohm bussed resistor. Note that this resistor is polarized and only can go in one way. The dot on the package denotes pin1.
- □ Install Capacitors
- □ Install Diodes
- □ Instal IC Sockets
The notch faces right.
The Notch faces right.
- □ Install LEDs
- □ D3,D4 - Red LED. LEDs are polarized and they have to be installed with the correct orientation. The anode side of the LED with the longer leg goes in the top round hole.
- □ Install Voltage Regulator
- □ Install Fuse Holder
- □ Install Connectors
- □ Install RJ45 Jacks
- □ Install Fuse
- □ Install ICs
Configure Jumpers
Install a jumper across Pin 1 and Pin2 if you are using RS232 Input to the controller. Install a jumper across Pins 2 and Pin 3 if you are using regular RS485 input.
J3- 2x5 Options Connector
J4- Options Programing
J7- Voltage Selector
Program PIC
J2-ICSP Programming Header
| Pin # | ||
| Signal | ||
| 1 | VPP/MCLR | |
| 2 | VDD Target | |
| 3 | VSS (Ground) | |
| 4 | ICSPDAT/PGD | |
| 5 | ICSPCLK/PGC | |
| 6 | N/C | |
Connections
| Pin # | RJ45 Connector | |
| J5 Input | J6 Output | |
| 1,2 | GND | GND |
| 3 | NC | NC |
| 6,7,8 | NC | NC |
J8-Pixel Power Input
| J8 Power Input | ||
| Pin # | ||
| Voltage | ||
J9 - Output to Pixels
| Pin # | ||
| Signal | ||
| 1 | GND (V-) | |
| 2 | Clock (C) | |
| 3 | Data (D) | |
| 4 | V+ | |
Indicator LEDs
Attn
Rx
FE
Pwr
- Baud Rate: Allows you to set the controller to match the speed of your existing Renard network.
- Number of Pixels: Allows you to set the specific number of pixels to be attached to controller (1-200)
- RGB Order: Allows to make corrections for strings where the pixels respond in a different color order UNDER DEVELOPMENT
- Grouping: Allows you to treat multiple pixel as one pixel, cutting down on the number of channels used. UNDER DEVELOPMENT
Enclosure
