Assembly Instructions For The REN 32
Board Assembly
- The following sequence of steps is by no means the only way to assemble the Ren32. It is simply a suggested order of events to achieve the desired goal. You can click on any photo for an enlarged view of that photo.
- NOTE: The part numbers referenced in the following instructions are those taken from the REN 32 BOM.
- JP1 & JP2 Configuraton
- JP1 installed
- JP2 not installed
- JP1 not installed
- JP3 Configuraton
Parts Listing (BOM)
IMPORTANT BOM INFORMATION:
QTY | REF | NOMENCLATURE |
511-LF50CV | 1 | U1 | 5 VDC Voltage Regulator |
532-577102B00 | 1 | Heatsink for Voltage Regulator | |
782-H11AA1 | 1 | U2 | Optocoupler, Bi-Directional Input |
815-ACH-18.432-EK | 1 | U3 | Crystal Clock Oscillator, 18.432 MHz |
511-ST485BN | 2 | U4, U5 | Differential Bus Transceivers |
571-1-390261-2 | 2 | IC Socket, 8 pin (for U4 & U5) | |
579-PIC16F688-I/P | 4 | U6-U9 | PIC Microcontroller |
571-1-390261-3 | 4 | IC Socket, 14 pin (for U6-U9) | |
571-1-390261-1 | 1 | IC Socket, 6 pin (for U2) | |
291-750-RC | 2 | R1, R2 | Resistor, Carbon Film 750 ohms 1/4W 5% |
291-120-RC | 1 | R3 | Resistor, Carbon Film 120 ohms 1/4W 5% |
299-1K-RC | 2 | R4, R7 | Resistor, Carbon Film 1K ohms 1/8W 5% |
299-27K-RC | 3 | R5, R8, R9 | Resistor, Carbon Film 27K ohms 1/8W 5% |
299-680-RC | 1 | R6 | Resistor, Carbon Film 680 ohms 1/8W 5% |
264-330-RC | 1 | RN1 | Resistor Network, 6 pin, 330ohms 2% |
625-1N5817-E3 | 4 | D1-D4 | Diode |
78-1N5239B | 1 | D6 | Diode, Zener 9.1V .5W |
78-1N5229B | 1 | D5 | Diode, Zener 4.3V .5W |
604-WP710A10IT | 2 | FE, OE | LED, 3mm Red |
604-WP710A10GT | 4 | PWR, HB, ZC, SD | LED, 3mm Green |
140-REA222M1CBK1320P | 1 | C1 | Radial Electrolytic Capacitor 16V 2200uF 20% |
140-REA470M1CBK0511P | 1 | C2 | Radial Electrolytic Capacitor 16V 47uF 20% |
80-C322C104K5R | 4 | C3-C6 | Capacitor, Radial Ceramic 50V 0.1uF |
571-7969492 | 1 | Power Terminals | Terminal Block, 2 Pos 5.08 mm |
571-5556416-1 | 10 | J1-J10 | Jack, Modular RJ45 PCB Mount Top Entry |
538-22-03-2021 | 3 | JP1-JP3 | Header, 2 Pin |
737-MSA-G | 3 | Shunt | |
504-GMA-10 | 1 | F1, F2 | Fuse, Fast Acting 10A |
534-3517 | 2 | Holder, Fuse Clip PCB mount 5mm | |
534-3527C | 1 | Cover, Fuse | |
838-3FD-412 | 1 | TF1 | Power Transformers 12.6VAC CT 6.0VA Dual Primary |
Hardcopy Instructions
- Board Availability Information]
