10W-RGB-LED-DRIVER
![Version G2](/wiki/images/8/86/10W_RGB_Driver_Top.jpg)
10W RGB LED
![small](/wiki/images/9/96/10W_RGB_LED_smaller.jpg)
Color: RGB
Beam Angel: 140 degrees
Life span: >50,000 hours
less than 1" square.
![Version G2](/wiki/images/c/c5/10W_RGB_Driver_Bottom.jpg)
BOM for 12V DC power input:
QTY Board ID Description 3 IC1,IC2,IC3 PT4115 by Powtech: 30V, 1.2A Step-down High Brightness LED Driver with 5000:1 Dimming 3 L1,L2,L3 100uH Inductor, 6x8mm, 500ma 3 T1,T2,T3 Transistor FJN3314R 3 D1,D2,D3 Diode 1N5819 3 R1,R2,R3 Resistor, 1/4 Watt, 0.33 Ohm, 5% or better, carbon or metal film 3 R4,R5,R6 Resistor, 1/4 Watt, 4.7K (4K7) Ohm, 5% or better, carbon or metal film 1 IC4 Voltage Regulator, 5V 78L05 1 C1 Electrolytic Capacitor 100uF 35v (polarized) 1 C2 MLCC Ceramic Capacitor .1uF 50v (monolithic)
Assembly Tips
![Version G2](/wiki/images/a/a5/10W_non_groupby_version_builtup.jpg)
Mounting the LED:
Soldering Sequence
Wiring examples
Note !! This section is under assembly and will be greatly expanded
General Notes
Testing your board
After your initial build, you can test your board with a 12V DC input and a jumper wire. Here is a link to a YouTube Video that shows this test. Initial test video
REN48LSD connections
![](/wiki/images/thumb/f/fa/10W_RGB_REN48lsd_hookup_diagram.jpg/300px-10W_RGB_REN48lsd_hookup_diagram.jpg)
Installation examples
![](/wiki/images/thumb/7/78/10W_flood_installation_by_livermore_dad.jpg/300px-10W_flood_installation_by_livermore_dad.jpg)
![](/wiki/images/thumb/0/0d/10w_brd_mounted.jpg/300px-10w_brd_mounted.jpg)
![](/wiki/images/thumb/f/fd/10W_schematic.png/300px-10W_schematic.png)
![](/wiki/images/e/e9/10W_board_xray.png)
Where can I get one of these wonderful boards?
