10W-RGB-LED-DRIVER
10W RGB LED
Color: RGB
Beam Angel: 140 degrees
Life span: >50,000 hours
less than 1" square.
When using this LED with the 10W Driver board, you need to remove the bar along the anodes that tie them together.
Do NOT snip the anodes themselves off. Just the linking bar. When you are done, both sides of the LED should look the same.
BOM for 12V DC power input:
QTY Board ID Description 3 IC1,IC2,IC3 PT4115 by Powtech: 30V, 1.2A Step-down High Brightness LED Driver with 5000:1 Dimming 3 L1,L2,L3 100uH Inductor, 6x8mm, 500ma 3 T1,T2,T3 Transistor FJN3314R 3 D1,D2,D3 Diode 1N5819 3 R1,R2,R3 Resistor, 1/4 Watt, 0.33 Ohm, 5% or better, carbon or metal film 3 R4,R5,R6 Resistor, 1/4 Watt, 4.7K (4K7) Ohm, 5% or better, carbon or metal film 1 IC4 Voltage Regulator, 5V 78L05 1 C1 Electrolytic Capacitor 100uF 35v (polarized) 1 C2 MLCC Ceramic Capacitor .1uF 50v (monolithic)
Assembly Tips
Mounting the LED:
Soldering Sequence
The trick to soldering these little fellows are to:
1. Use some liquid flux on the pads
2. Use a fine, clean, tip on your soldering iron
3. Use VERY LITTLE SOLDER ! A fine gauge solder would be helpful
You should concentrate on tacking down one of the the outermost pads (not the center pad) to hold the IC in place.
Once you do this, the rest will be much easier.
Wiring examples
Note !! This section is under assembly and will be greatly expanded
General Notes
REN48LSD connections
Testing your board
After your initial build, you can test your board with a 12V DC input and a jumper wire.
Here is a link to a YouTube Video that shows this test.
Initial test video
Installation examples
Click here to download the schematic as a pdf: File:10w fjn5 sch-1.pdf
Where can I get one of these wonderful boards?
