ESPixel Stick & ESPixel Pops
This variation was created by Pops Jones (ukewarrior) in order to create a form factor that would fit inside a 1" thin wall PVC tube.
2. B
3. C
4. C
Order your own boards
Since there is no onboard fuse, if a power overload should occur, the ESP-01 or the ESPixel Pops board may be damaged. You can add an inline fuse if desired inline with the input power feed.
BOM for 120VAC Operation:
QTY Mouser #: Description
2 606-A9A Neon Lamp 65VAC .7mA NE-2E marked NE1, NE2 (See the note below for an alternative source)
OR
511-BTA06-600S Triacs 6 Amp 600 Volt marked U1, U2, U3, and U4
1 534-3527C Fuse Cover
4 859-MOC3023 Optocomponents Optocoupler marked IC1, IC2, IC3 and IC4
See above for TA-200 sources.
1 TA-200 Enclosure
1 Male Plug Power Cord, Rated for 10A Minimum
Here is a picture of a completed ESPixel Pops: (The fuse cover has been removed)
Updated picture to be added....
Wiring The ESPixel Pops
Controller Output Pinout
