ESPixel Stick & ESPixel Pops
The genesis of the pixel stick controllers started with designes by Bill Porter.
This variation was created by Pops Jones (ukewarrior) in order to create a form factor that would fit inside a 1" thin wall PVC tube.
4. The board is small enough to fit inside a 1" thinwall PCB pipe with the board measuring only 24.18x33.32 mm
Order your own boards
Here is a picture of a completed ESPixel Pops: (The fuse cover has been removed)
Updated picture to be added....
Wiring The ESPixel Pops
Controller Output Pinout
