ESPixel Stick & ESPixel Pops
The ESPixel Pops and ESPixel Pops Tiny are variations of the original ESPixel Stick by Bill Porter
The genesis of the pixel stick controllers started with designs by Bill Porter.
The ESPixel Pops is the most basic of the Pixel Stick designs.  It is a fully through hole PCB with no smd(surface mount) components.  Therefore, it is easily built by most anyone with basic soldering skills.
From a software perspective, it is an E1.31 sACN (Streaming ACN) pixel controller that connects over a standard (802.11g/n) WiFi network.  The firmware is open source and developed in the ESP8266 Arduino environment.  It provides a web based configuration front-end and currently supports WS2811 / WS2812 pixels. (3-wire pixels)
5.  The board is small enough to fit inside a 1" thinwall PCB pipe with the PCB measuring only 24.18x33.32 mm and 24.18x24.61 mm for the tiny version.  This type of pipe is listed as SDR-21.
Order your own boards
- One diode.  This must be: 1N4148
- One female socket header, 2 rows of pins, 4 pins in each row.  This functions as the socket where you plug the ESP8266 module into
- One six pin header.  Readily available 2.54mm (.1") pitch. (distance between the pins)
- One tactile switch.  6mm x 6mm. Also readily available. These often have choices as to the height of the push button.
- Two 1/8W or 1/4W carbon film or metal film resistors.  330 Ohms.
- One polarized Electrolytic capacitor.  Any value from 10uF to 220uF will do. 10V or above. Pay special attention to the diameter and spacing of the leads. The diameter can be no more than 5mm and the leads should be spaced at 2mm.
- One MLCC monolithic capacitor. 2.54mm lead spacing.  0.1uF, any voltage over 24V. (Usually these are 50V rated) These are typically the 'yellow blob' style capacitors, verses the ones that are shaped like a flat disk.  These do NOT have a + & - indication, unlike the electrolitic capacitor noted above.
- One 5.0v voltage regulator.  This part is optional and should only be installed if you are planning to drive 12v pixels.
- One Mosfet.  This must be: 2N7000, which has a T0-92-3 style package
- A five pin screw terminal header.  5 positions total.  This connection should have 3.81mm spacing of the mounting pins.
Click Here:
The BOM's are:
Mouser BOM is in Post #35
Arrow BOM is in Post #48
Digikey BOM is in Post #49
The ESPixel Pops is a pretty easy build.  The real trick is deciding how you plan to power your pixels as that will affect what you do with the board wiring.
 This module does not care if you are running 5V or 12V pixels.  So, you can connect 5V or 12V to the board.
The board has a place for a second voltage regulator.  This is to accommodate 5V pixels even if your input power is 12V.
This is location IC1 on the board.  This is a spot for either a 5V regulator or a wire jumper.
Wiring The ESPixel Pops
You can either solder on a terminal block or directly solder your wires to the board, or do a mix ! The Terminal block has 3.81mm hole spacing. (The more common 5mm terminal blocks would have made the board too wide)
One thing you have to decide is if you will power your pixels through the ESPixel Stick or directly to the Pixel string. It is possible to use the ESPixel Pops as an interface for just the data and run power to the pixels separately. This is a decision of personal preference and the fact the PCB traces can only handle so much power. Trial and error is your best approach.
