ESPixel Stick & ESPixel Pops
Revision as of 16:03, 23 October 2017 by Ukewarrior (talk | contribs)
Version V2
Version V2
Version V2
Version V2
Version V2
Version V2
Pixel Pops & Tiny
small
small
5. Supports up to 63 GECE Pixels 6. It supports both 5v and 12v pixels
Order your own boards
- One Mosfet. This must be: 2N7000 or ZVN3306A, which has a T0-92-3 style package
The BOM's are:
Mouser BOM is in Post #35
Arrow BOM is in Post #48
Digikey BOM is in Post #49
Version V2
Version V2
The board has a place for a second voltage regulator. This is to accommodate 5V pixels even if your input power is 12V.
The part laveled: IC1 is NOT installed if you are running 5V Pixel strings AND you must place a jumper in its place as noted on the board.
Wiring The ESPixel Pops
A Key Point Regarding Power
One thing you have to decide is if you will power your pixels through the ESPixel Stick or directly to the Pixel string.
Programming the ESP-01 Module
Under Construction
