ESPixel Stick & ESPixel Pops
Revision as of 13:13, 30 October 2017 by Ukewarrior (talk | contribs) (→‎Fuses)
Version V2
Version V2
Version V2
Version V2
Version V2
Version V2
Pixel Pops & Tiny
small
small
4. Supports up to 680 WS2811 or WS2812 Pixels - 4 Universes of DMX data 5. Supports up to 63 GECE Pixels 6. It supports both 5v and 12v pixels
Order your own boards
Fuse Holder
5A Fuse
The BOM's are:
Mouser BOM is in Post #35
Arrow BOM is in Post #48
Digikey BOM is in Post #49
Version V2
Version V2
Wiring The ESPixel Pops
A Key Point Regarding Power
Programming the ESP-01 Module
