ESPixel Stick & ESPixel Pops
Revision as of 13:15, 30 October 2017 by Ukewarrior (talk | contribs) (→‎Fuses)
Version V2
Version V2
Version V2
Version V2
Version V2
Version V2
Pixel Pops & Tiny
small
small
4. Supports up to 680 WS2811 or WS2812 Pixels - 4 Universes of DMX data 5. Supports up to 63 GECE Pixels 6. It supports both 5v and 12v pixels
Order your own boards
Fuse Holder
5A Fuse
Version V2
Version V2
[[glass fuse.jpg}right]]
The BOM's are:
Mouser BOM is in Post #35
Arrow BOM is in Post #48
Digikey BOM is in Post #49
Version V2
Version V2
Wiring The ESPixel Pops
A Key Point Regarding Power
Programming the ESP-01 Module
