Pops-O-Matic ESP Programmer
Voltage Regulator
ESP Flashing Circuit
Pops-O-Matic Overview
1. 5mm Terminal Block
2. 3.5mm Terminal Block
3. Micro USB
4. Mini USB
5. Barrel Terminal Jack
Order a board
You can also order one off of TAYDA and is in the example BOM from noted below.
Errata
There is an unwanted trace on the back of the board that connects the right most pin of part C5 to the ground backplane that covers the bottom of the board.
