All In One Tester
Now let's build a tester.
The Parts
After the board has been etched, it needs to be cut to the profile trace so it will fit into the enclosure. The mounting holes should be drilled 1/8".
A few things on assembly. The LED spacers..... The long ones are for the small LEDs, and the short ones are for the large LEDs. When inserting the small LEDs, make sure they are fully seated into the recess of the spacer. The large LEDs will just rest on top of the spacer. With all of the LEDs, the short lead goes into the square pad. When soldering the LEDs, it is very important that they are straight in line and perpendicular to the board so they will line up with the holes in the case.
The headers and connectors.....The two pin connectors have a 'locking ramp' on them, this will need to be removed. I used a razor blade. (I was going to use the SL series two pin connectors to keep things matched, but just one cost more than both of the KK series connectors.) When soldering the headers, I inserted them into the connectors to hold them at the right height.
This is optional, Some heat shrink on the large LEDs will cut down on the light from one 'bleeding' over to the one beside it. Cut the tubing 3/32" and just slip it over the LED, no need to shrink it. If these are too long, the enclosure will not want to go together. This is not needed for the small LEDs nor the mobile unit's LEDs.
Switches and stuff
Power
Power for the board is a 9V battery and an 'optional' DC jack. If you choose to use a DC jack make sure it has a NC switch and is wired properly. If you use the one I listed in the parts section, the + side of the header connector and the + side of the battery wire to the center pin. The - side of the battery to one of the shell tabs, and the - side of the header connector to the other shell tab.
Never exceed 9v when using the DC jack , you could damage your Tester and SSR's if you do.
The Enclosure
Drill the large LEDs holes with a #8 drill bit.(if you do not have one then a 13/64 will do, it's .004 bigger though) Drill the small LED holes with a #32 drill bit.
Finishing Touches
Now we can install the switches and DC jack. Find a piece of foam 3/8" thick for a battery pad. A couple dabs of hot glue, or double sided tape works well to hold it place. If you used the 4-40 PCB stand offs, you will need five 1/4" 4-40 screws. I couldn't find them that short, so I cut some down. I used a 4-40 tap to thread the bosses, then ran a 4-40 screw into them to finish out the threads to the bottom. The stand offs have to be seated with the bosses when screwed in. Plug in the connectors. The wires will need formed a bit to clear things and fit well.
