Serial, RS232
Voltages
Level | Transmitter capable (V) | Receiver capable (V) |
Space state (0) | +5 ... +15 | +3 ... +25 |
Mark state (1) | -5 ... -15 | -3 ... -25 |
Undefined | - | -3 ... +3 |
Pinouts
Pin No.NameDirNotes/Description 1DCDINData Carrier Detect. Raised by DCE when modem synchronized. 2RDINReceive Data (a.k.a RxD, Rx). Arriving data from DCE. 3TDOUTTransmit Data (a.k.a TxD, Tx). Sending data from DTE. 4DTROUTData Terminal Ready. Raised by DTE when powered on. In auto-answer mode raised only when RI arrives from DCE. 5SGND-Ground 6DSRINData Set Ready. Raised by DCE to indicate ready. 7RTSOUTRequest To Send. Raised by DTE when it wishes to send. Expects CTS from DCE. 8CTSINClear To Send. Raised by DCE in response to RTS from DTE. 9RI IN Ring Indicator. Set when incoming ring detected - used for auto-answer application. DTE raised DTR to answer.
Achievable distances
The maximum distance that RS323 can go varies depending on Bit Rate and also the capacitance of the wire itself. Texas Instruments states that RS 232 maximum cable length is 50 feet, or the cable length equal to a capacitance of 2500 pF. Depending on the cable such as Category 5 Twisted pair the maximum achievable distance at 19200 is 157 feet.
here is a quick chart showing theoretical limits as various data rates for RS232 cable length according to Texas Instruments
Baud rate | Maximum cable length (ft) |
19200 | 50 |
9600 | 500 |
4800 | 1000 |
2400 | 3000 |
