Serial, RS232
Voltages
Level | Transmitter capable (V) | Receiver capable (V) |
Space state (0) | +5 Vdc up to +15 Vdc | +3 Vdc up to +25 Vdc |
Mark state (1) | -5 Vdc up to -15 Vdc | -3 Vdc up to -25 Vdc |
Undefined | - | -3Vdc up to +3Vdc |
Pinouts
View - looking into Male connector | View - looking into Female connector |
Pin No. | Name | Dir | Notes/Description |
1 | DCD | IN | Data Carrier Detect. Raised by DCE when modem synchronized. |
2 | RD | IN | Receive Data (a.k.a RxD, Rx). Arriving data from DCE. |
3 | TD | OUT | Transmit Data (a.k.a TxD, Tx). Sending data from DTE. |
4 | DTR | OUT | Data Terminal Ready. Raised by DTE when powered on. In auto-answer mode raised only when RI arrives from DCE. |
5 | SGND | - | Ground |
6 | DSR | IN | Data Set Ready. Raised by DCE to indicate ready. |
7 | RTS | OUT | Request To Send. Raised by DTE when it wishes to send. Expects CTS from DCE. |
8 | CTS | IN | Clear To Send. Raised by DCE in response to RTS from DTE. |
9 | RI | IN | Ring Indicator. Set when incoming ring detected - used for auto-answer application. DTE raised DTR to answer. |
Achievable distances
The maximum distance that RS323 can go varies depending on Bit Rate and also the capacitance of the wire itself. Texas Instruments states that RS 232 maximum cable length is 50 feet, or the cable length equal to a capacitance of 2500 pF. Depending on the cable such as Category 5 Twisted pair the maximum achievable distance at 19200 is 157 feet.
here is a quick chart showing theoretical limits as various data rates for RS232 cable length according to Texas Instruments
Baud rate | Maximum cable length (ft) |
19200 | 50 |
9600 | 500 |
4800 | 1000 |
2400 | 3000 |
Interfacing to Microcontrollers
In order for RS232 to communicate with a Microcontroller such as a Pic16f88 or Atmel, level conversion must first be done because of the voltage levels on TTL is 5 Vdc max and normal RS232 far exceeds voltage limitations and damage will occur.
Devices such as a MAX232 will make the necessary voltage conversion possible for communication to and from TTL devices.
