4 Channel SSROZ Assembly Instructions
Background
I was a late starter to the CC.com website last year and missed out on Sean Bowf's COOP for SSRs and decided that I would go ahead and make some of my own. This SSR design is a result of collaboration with Sean in January and February 2007, making sure that this design follows the guidance for SSRs as published on www.simpleIO.com and my calculations and testing.
The SSROZ design is currently in it's 4th iteration.
Prototype SSROZ 2.5a
Version History
SSROZ 2.5a, was the first. This is a single side board, 2.2 x 2.0 inches. A small production batch were made and distributed in Australia.
SSROA 2.5c, Main production run, based on 2.5b. JAYCAR vertical fuse holder, 400 mil pins. White silkscreen are non-ROHS, Yellow silkscreen are ROHS.
SSROZ 2.5d, Main Production run, based on 2.5b. Mouser vertical fuse holder, 315 mil pins. Yellow silkscreen are ROHS are now standard.
