SSRneon
The SSRneon is a 4 port AC Solid State Relay (SSR). It is derived from the same basic design that has been in general use by the DIY community for many years. Most of the DIY SSRs are derived from Sean Boef's original 4 port SSR. The design has evolved over the years, but the core functions and parts are the same. The SSRoz and SSRez are two such designs.
The SSRneon is very similar to the SSRez and shares almost exactly the same Bill of Materials (BOM) as the SSRez. There is one replacement and two additions.
Safety Features
The SSRneon optionally contains two NE-2E neon lights. These lights are what differentiates the SSRneon from the other available SSRs. The point of these neon lamps is they serve as a safety warning that AC voltage (which can be lethal) is present on the SSR PCB. One bulb lights if AC voltage is attached to the board. The second bulb lights if AC voltage has successfully passed through the on-board fuse. Neons are used instead of an incandescent blub due to the fact that a neon bulb is very long lived and is much 'tougher' then an incandescent since there is no filament to break.
A heatsink can be fashioned and attached to the TRIACs.
The board has two points to mount it to the TA-200 enclosure. I went to great pains to make sure that the screws that come with the enclosure can be used once they have been cut down to a proper length.
The board is home etch friendly. I tried to keep the traces wide with good spacing. You will also notice that I rounded all the corners since this makes for a better home etch.
Bill of Materials
QTY Mouser #: Description
1 571-5556416-1 Modular Jacks 8 PCB TOP ENTRY marked RJ45
4 511-BTA04-700T Triacs 4 Amp 700 Volt marked Q1, Q2, Q3, and Q4
1 604-WP7104IT LED Standard HI EFF RED TRANS marked LED
5 660-CF1/4C681J 1/4Watt Axial Leaded Carbon Film Resistors 680ohms 5% marked R1, R2, R3, R4 and R11
4 660-CF1/4C181J 1/4Watt Axial Leaded Carbon Film Resistors 180ohms 5% marked R5, R6, R7 and R8
4 660-CF1/4C181J 1/4Watt Axial Leaded Carbon Film Resistors 100Kohms 5% marked R9, R10,
4 859-MOC3023 Optocomponents Optocoupler TRIAC marked U1, U2, U3 and U4
4 571-1-390261-1 IC Sockets 6P ECONOMY TIN (Optional!) also marked Q1, Q2, Q3 and Q4
5 571-28228372 Terminal Blocks 5.08MM PCB MOUNT 2P
1 TA-200 Enclosure
240VAC Operation
FireGod
If the SSRez is going to be used with a FireGod system, Resistors R5-R8 may need to be changed. If the channel LEDs are used on the field modules AND the interface board voltage regulator is 5VDC, replace R5, R6, R7, R8, and R9 with 510 Ohm Resistors. You must also use the "Sinking Code" in the FireGod Field Modules when using the SSRez.
15. Install the fuse.
Wiring The SSRez
Heat Sink
Template Coming Soon
Troubleshooting
'This section is under construction...please do not use for the time being....
Symptom(s):
Possible Problem(s):
- Bad triac
- Triac in Backwards
- Bad opto
- Opto/MOC in Backwards
- Bad/missed Solder Joints
Troubleshooting Flow
Troubleshooting Steps
- Turn OFF AC power
- Are any of the triac gate resistors (R1-R4) burnt/blown/damaged?
- If so, replace that resistor and check the solder pads on the associated TRIAC. Blown gate resistors are usually caused by a missed solder connection on the TRIAC.
- Remove the PIC from the controller for this channel.
- Connect power to the H and N terminal blocks
- Turn ON AC power
- Test lights should be OFF
- If the test lights are ON, go to step <XX>
- Test lights should come ON when the jumper is connected to the locations in the table. Now this table has eight tests as they are the 8 channels from a single PIC Microcontroller. However, the SSRez has only 4 channels. The channels in the chart for 5-8 are for a different SSRez.
Controller
ChannelOptoisolator Test Lights
at SSRezConnect Jumper Wires between 1 U1 Channel 1 2 U2 Channel 2 3 U3 Channel 3 4 U4 Channel 4 5 U1 Channel 1 6 U2 Channel 2 7 U3 Channel 3 8 U4 Channel 4
- Turn OFF AC power
- Install PIC back into the controller
- Turn OFF AC power
- Replace the opto (U1-U4) controlling the bad channel
- Turn OFF AC power
- Remove the opto (U1-U4) controlling the bad channel
- Turn ON AC power
SAFETY NOTICE:
- Bad triac
- It should be 5 VDC
- If incorrect, check the current limiting resistor (R5-R8) associated with that opto. You should be able to read approx 5 VDC on both sides of the resistor.
- Turn OFF AC power
- Turn ON AC power
- Is the test light still ON?
Early Prototype Picture
