SSRneon
![Version G2](/wiki/images/8/8c/SSRneon_G2_.jpg)
Safety Features
![ne-2E](/wiki/images/9/97/Ne-2e_picture.jpg)
![Neon glow.jpg](/wiki/images/f/f1/Neon_glow.jpg)
The SSRneon optionally contains two NE-2E neon lights. These lights are what differentiates the SSRneon from the other available SSRs.
A heatsink can be fashioned and attached to the TRIACs.
The board has two points to mount it to the TA-200 enclosure. I went to great pains to make sure that the screws that come with the enclosure can be used once they have been cut down to a proper length.
Home Etch
![copper](/wiki/images/1/1d/Ssrneon_copper_in_color.jpg)
The board is home etch friendly. It is single sided. Effort was made to keep the traces wide with good spacing. You will also notice that all the trace corners are rounded since this makes for a better home etch. A special version of the copper side was created. It matches the layout of the production board. However, all of the large through holes have been 'filled-in with only a small dot in the middle of the copper removed. This allows the home etched to drill these holes whatever size he likes and still have adjacent copper to the hole's edge.
The etch files are .pdf format. Be sure to print these with the actual size attributes set withing Acrobat.
The copper image can be found here: The silkscreen image can be found here: The image of the product board can be found here:
Bill of Materials
QTY Mouser #: Description 2 606-A9A Neon Lamp 65VAC .7mA NE-2E 1 571-5556416-1 Modular Jacks 8 PCB TOP ENTRY marked RJ45 1 504-GMC-7 5mm x 20mm Medium Time Delay Fuses 125VAC 7A Med Time Delay 4 511-BTA04-700T Triacs 4 Amp 700 Volt marked Q1, Q2, Q3, and Q4 2 534-3517 Fuse Clips and Holders PC FUSE CLIP 5 MM 1 604-WP7104IT LED Standard HI EFF RED TRANS marked LED 5 660-CF1/4C681J 1/4Watt Axial Carbon Film Resistors 680ohms 5% marked R1, R2, R3, R4 and R11 4 660-CF1/4C181J 1/4Watt Axial Carbon Film Resistors 180ohms 5% marked R5, R6, R7 and R8 2 660-CF1/4C103J 1/4Watt Axial Carbon Film Resistors 100Kohms 5% marked R9, R10, 4 859-MOC3023 Optocomponents Optocoupler TRIAC marked U1, U2, U3 and U4 4 571-1-390261-1 IC Sockets 6P ECONOMY TIN (Optional!) also marked Q1, Q2, Q3 and Q4 5 571-28228372 Terminal Blocks 5.08MM PCB MOUNT 2P 2 Screw,#8x1/2" Pan Head Sheet Metal (You can use the screws that come with the TA-200 if you cut them down) 1 TA-200 Enclosure 1 Male Plug Power Cord, Rated for 8A Minimum 4 Female Plug Power Cord, Rated for 4A Minimum
Now the above is the base Bill of Materials for 120VAC operation. Other Source Voltages are possible. These are listed below.
240VAC Operation
FireGod
If the SSRez is going to be used with a FireGod system, Resistors R1-R4 may need to be changed. If the channel LEDs are used on the field modules AND the interface board voltage regulator is 5VDC, replace R1, R2, R3, R4, and R11 with 510 Ohm Resistors. You must also use the "Sinking Code" in the FireGod Field Modules when using the SSRez.
![](/wiki/images/thumb/3/32/SSRez_Step1.jpg/200px-SSRez_Step1.jpg)
![](/wiki/images/thumb/b/bd/SSRez_Step3.jpg/200px-SSRez_Step3.jpg)
![](/wiki/images/thumb/5/51/SSRez_Step4.jpg/200px-SSRez_Step4.jpg)
![](/wiki/images/thumb/9/92/SSRez_Step5.jpg/200px-SSRez_Step5.jpg)
![](/wiki/images/thumb/b/b6/SSRez_Step6.jpg/200px-SSRez_Step6.jpg)
![](/wiki/images/thumb/0/0b/SSRez_Step7.jpg/200px-SSRez_Step7.jpg)
![](/wiki/images/thumb/4/4a/SSRez_Step8.jpg/200px-SSRez_Step8.jpg)
![](/wiki/images/thumb/6/69/SSRez_Step9.jpg/200px-SSRez_Step9.jpg)
![](/wiki/images/thumb/e/ea/SSRez_Step10.jpg/200px-SSRez_Step10.jpg)
15. Install the fuse.
![](/wiki/images/thumb/c/c0/SSRez_Step15.jpg/200px-SSRez_Step15.jpg)
Wiring The SSRez
Original SSRneon
The original SSRneon was not designed for any particular enclosure. It has only one neon bulb to signal the presence of AC before it passes through the fuse.
