SSRneon
Safety Features
The SSRneon contains two NE-2E neon light bulbs. These lights are what differentiates the SSRneon from the other available SSRs.
A heatsink can be fashioned and attached to the TRIACs. Use of a heatsink should boost the continuous amp capacity from 4 amps to 7 amps. A heatsink should not be necessary unless the load for any single channel (Tirac) exceeds 1 amp.
The board has two points to mount it to the TA-200 enclosure. I went to great pains to make sure that the screws that come with the enclosure can be used once they have been cut down to a proper length.
Home Etch
The copper image can be found here: The silkscreen image can be found here: The image of the product board can be found here:
Fuse Size
Various fuse values have been listed for all the various 4 port SSRs. e.g. Sean Beof, SSRoz, SSRez.
The SSRneon-G2 has the largest combination of trace sizes and copper weight of any of the DIY SSRs to date. (6/17/2011) With that said, a Fuse of 4 amps is a good place to start. If you want to drive more then 1 amp through any individual Triac (channel), then you can ramp up to as high as a 7 amp fuse. However, once you move above 1 amp through any single Triac (channel), you should put a heat sink on the Triac(s).
It is this authors opinon that you should run as low a fuse value as you need for needs. For example, this author runs a 100% LED based show and runs several SSRneons with 2 amp fuses.
QTY Mouser #: Description 2 606-A9A Neon Lamp 65VAC .7mA NE-2E 1 571-5556416-1 Modular Jacks 8 PCB TOP ENTRY marked RJ45 1 504-GMC-7 5mm x 20mm Medium Time Delay Fuses 125VAC 7A Med Time Delay 4 511-BTA04-700T Triacs 4 Amp 700 Volt marked Q1, Q2, Q3, and Q4 2 534-3517 Fuse Clips and Holders PC FUSE CLIP 5 MM 1 604-WP7104IT LED Standard HI EFF RED TRANS marked LED 5 660-CF1/4C681J 1/4Watt Axial Carbon Film Resistors 680ohms 5% marked R1, R2, R3, R4 and R11 4 660-CF1/4C181J 1/4Watt Axial Carbon Film Resistors 180ohms 5% marked R5, R6, R7 and R8 2 660-CF1/4C103J 1/4Watt Axial Carbon Film Resistors 100Kohms 5% marked R9, R10, 4 859-MOC3023 Optocomponents Optocoupler TRIAC marked U1, U2, U3 and U4 4 571-1-390261-1 IC Sockets 6P ECONOMY TIN (Optional!) also marked Q1, Q2, Q3 and Q4 5 571-28228372 Terminal Blocks 5.08MM PCB MOUNT 2P 2 Screw,#8x1/2" Pan Head Sheet Metal (You can use the screws that come with the TA-200 if you cut them down) 1 TA-200 Enclosure 1 Male Plug Power Cord, Rated for 8A Minimum 4 Female Plug Power Cord, Rated for 4A Minimum
Now the above is the base Bill of Materials for 120VAC operation. Other Source Voltages are possible. These are listed below.
240VAC Operation
FireGod
15. Install the fuse.
Wiring The SSRez
Original SSRneon
The original SSRneon was not designed for any particular enclosure. It has only one neon bulb to signal the presence of AC before it passes through the fuse. You must also wire a 100K resistor inline with the single neon bulb leads because there is no separate attachment point for the resistor.
