SSRneon
Safety Features
The main safety feature of any SSR is the main FUSE. This is discussed in a separate section below.
The SSRneon contains two NE-2E neon light bulbs. These lights are what differentiates the SSRneon from the other available SSRs.
A heatsink can be fashioned and attached to the TRIACs. Use of a heatsink should boost the continuous amp capacity from 4 amps to 7 amps. A heatsink should not be necessary unless the load for any single channel (Tirac) exceeds 1 amp. These are usually made from a piece of aluminum since it cuts and drills easily and absorbs heat rapidly. See the example to the right. One safety note about heatsinks. You need to be sure the TRIACs you are using have what is know as an 'isolated tab.' The tab is the exposed metal pad with the hole in it. On some TRIACs the tab is 'hot' or has AC voltage present. It is hard to use a common heatsink with this style of TRIAC. The TRIAC listed in the BOM has an 'isolated tab' so it is suitable for use with a heatsink.
The board has two points to mount it to the TA-200 enclosure. I went to great pains to make sure that the screws that come with the enclosure can be used once they have been cut down to a proper length.
Home Etch
The copper image can be found here: The silkscreen image can be found here: The image of the product board can be found here:
Fuse Size
Various fuse values have been listed for all the various 4 port SSRs. e.g. Sean Bowf, SSRoz, SSRez.
The SSRneon-G2 has the largest combination of trace sizes and copper weight of any of the DIY SSRs to date. (6/17/2011) With that said, a Fuse of 4 amps is a good place to start. If you want to drive more then 1 amp through any individual Triac (channel), then you can ramp up to as high as a 7 amp fuse. However, once you move above 1 amp through any single Triac (channel), you should put a heat sink on the Triac(s).
QTY Mouser #: Description
2 606-A9A Neon Lamp 65VAC .7mA NE-2E
1 571-5556416-1 Modular Jacks 8 PCB TOP ENTRY marked RJ45
4 511-BTA04-700T Triacs 4 Amp 700 Volt marked Q1, Q2, Q3, and Q4
1 604-WP7104IT LED Standard HI EFF RED TRANS marked LED
5 660-CF1/4C681J 1/4Watt Axial Carbon Film Resistors 680ohms 5% marked R1, R2, R3, R4 and R11
4 660-CF1/4C181J 1/4Watt Axial Carbon Film Resistors 180ohms 5% marked R5, R6, R7 and R8
2 660-CF1/4C103J 1/4Watt Axial Carbon Film Resistors 100Kohms 5% marked R9, R10,
4 859-MOC3023 Optocomponents Optocoupler TRIAC marked U1, U2, U3 and U4
4 571-1-390261-1 IC Sockets 6P ECONOMY TIN (Optional!) also marked Q1, Q2, Q3 and Q4
5 571-28228372 Terminal Blocks 5.08MM PCB MOUNT 2P
1 TA-200 Enclosure
Now the above is the base Bill of Materials for 120VAC operation. Other Source Voltages are possible. These are listed below.
240VAC Operation
FireGod
15. Install the fuse.
Wiring The SSRez
Original SSRneon
The original SSRneon was not designed for any particular enclosure. It has only one neon bulb to signal the presence of AC before it passes through the fuse. You must also wire a 100K resistor inline with the single neon bulb leads because there is no separate attachment point for the resistor.
