		Pictures of Various FM02 Installations
	- FM02 Installations
![[[The enclosure is from Mouser P/N 563-NBF-32006. It's a water tight case, very overkill, but it was a handy size and I already had an order going so shipping wan't an issue. It's made by Bud Enclosures and cost $12.50. It comes with tabs that screw into the back and make for handy mounting. The plastic is thick but pliable, very easy to drill and work with.The power is supplied via a wall wart, goes in through a strain relief and into toggle switch and power indicating LED I got at Radio Shack. The power then goes into a LM317 regulator I bought in the DIYC group buy. For additional power filtering I added two 2200 uF capacitors to the output of the LM317 and routed it into the transmitter. The audio input is provided off a headphone jack from the computer line out. A stereo jack is mounted in the case and routed into the transmitter so a standard stereo cable can be used off the computer. I used a splitter off the computer audio line out to feed two stereo cables, one to the transmitter and the other to some speakers. I put a snap on ferrite bead (mouser P/N 810-ZCAT1730-0730A $1.20) onto the audio cable for good measure, I haven't had any noise issues, but also haven't tested without the bead.The transmitter board in the cover is attached using screws through the case lid and nylon spacers I got from Ace Hardware. The case is thick enough I had to put a relief in for some components to make the frequency display sit flush with the outside of the case. The boards on the inside of the case are mounted to a thin plexiglass panel I made from a larger piece I got from Lowes. I just scored it and snapped to fit. It mounts with two screws into the case body. The boards are attached to the plexiglass plate using screws and nylon spacers and some larger nuts (I ran out of spacers). I like the plexiglass because it isn't conductive (and looks cool) ]]](/wiki/images/thumb/7/73/FM02_OregonLights.jpg/150px-FM02_OregonLights.jpg)
