Glossary
A
- Amp
- Anode
- AWG
B
- Base
- Baud
- BNC
- BOM
C
- Capacitor
- Cathode
- Center Tap
- Channel
- COOP
- Coop Olsen 595
- COOP SSR
- Coaxial Cable
- Collector
- Continuity
- Current
D
- dB
- Decoupling capacitor
- Dielectric
- Diode
- DIP
- Dipole
- DIYC
- Do It Yourself Christmas.com
- DMX (or DMX512)
- Digital Multiplex. A lighting control protocol standard developed to handle communications between commercial (usually entertainment, such as theater or music events) lighting control boards and the individual devices, such as lekos (elliposoidals), fresnels, moving lights, strip lights or DJ effect lights. DMX allows up to 512 devices to be attached, daisy-chain, to one wire, each controlled individually. For more information on DMX click here.
E
- Electrode
- Electrolyte
- Electrolytic Capacitor
- Emitter
- Energized
- ESD
F
- Farad
- The basic unit of capacitance. A capacitor has a capacitance of 1 farad when a voltage potential of 1 volt across it produces a charge of 1 coulomb. Most capacitors used on DIYC boards are in the microfarad (labeled mF or uF) or picofarad (labeled pF) range.
- FCC
- FET
- Firmware
- Flux
- Full-Wave Rectifier
- Fuse
G
- GFCI
- GRINCH
- Ground
H
- Half-Wave Rectifier
- Heat Shunt
- Heat Sink
- A piece of metal attached to an electronic component (such as triac, transistor, or voltage regulator) that serves to dissipate or absorb unwanted heat. Many electronics components have two ratings, a lower one when a heat sink is not used and a higher one where a heat sink is in place. Also called a dissipator.
I
- Inductance
- Induction
- Insulated
- Insulation
- Insulation Resistance
- Insulator
- Integrated Circuit (IC)
- Inverter
J
- Jumper
K
L
- LED
M
- Microcontroller
- Mini-lights
- Incandescent bulbs that are about 7/32nds of an inch in diameter, they come in strings as short as 35 bulbs and as long as 400 bulbs. Officially known as the T1-3/4, the strings are wired in series and parallel, usually in 50-bulb groups (the 50 bulbs are in series which are then wired parallel to the others, making 100-, 150-, 200-, 250-, 300-, 350- or 400-bulb strings). Pretty universally, strings that are grouped by 50 bulbs can be cut down to 50-bulb strings. Mini-lights that are grouped by 50s use 2.5-volt, 170 mA bulbs, while 35-bulb strings use 3.5-volt bulbs. Mini-light bulbs are traditionally painted with a transparent paint, which can under severe or extended weather begin to chip or fade.
- MOC3023
- MOSFET
- MOV
- Multimeter
N
- NPN
O
- Ohm
- Ohm's Law
- Olsen 595
- Open or Open Circuit
- Oscillator
P
- Parallel Port
- PCB
- PIC
- Pixel
- A term traditionally used in computer graphics to identify a picture element, it has been adapted by the Christmas-lights community to refer to a tri-color (red-green-blue) LED that has an internal controller and is manufactured as a string, a strip (either rigid or flexible) or as modules. Pixels require three channels of sequencing software each, so 10 pixels are 30 channels and 50 pixels are 150 channels. Pixels can be based on any of a variety of controllers, including the TM18xx series, the LPD-6803, the WS2801, the 3001 and the GE ColorEffects chips. Further, pixels can be driven at either 5-volts or 12-volts DC and can have a variety of color orders. For strings, strips or modules of pixels to interoperate, they must have the same controller chip, the same voltage and the same color order (which usually means they must have the exact same manufacturer).
- Polarity
- Potentiometer
- Power
- Programmer
- Protocol
Q
R
- Regulator
- Relay
- Renard
- Resistance
- Resistor
- RJ-45 (or RJ45)
- RoHS
- RS232
- RS485
S
- Schematic
- Short Circuit
- Shunt
- Silk Screen
- Sink Current
- SMT (or SMD)
- SNR
- Source Current
- SPT(1-3)
- SSR
- DIYC definition
- SSROZ
- SWR
T
- Tinning
- Transformer
- Transistor
- Triac
- Twisted Pair
U
- ULN2803
- USB
V
- Via
- A plated-thru hole in a printed circuit board. A via may may exist between one or more adjacent board layers, or through the entire board. A blind via runs vertically between the top [or bottom] side and through one or more adjacent board layers, but not through the entire board.
- Voltage
- Voltage Drop
- Voltage regulator
- An electronic device designed to take a higher voltage and make it conform to a specific lower voltage. Provide a 5-volt regulator with 12 volts as an input and it will put out a steady 5 volts; provide a 12-volt regulator with 14.5 volts and it will output a steady 12 volts. While some regulators are designed for specific voltages, others can provide a range of voltages depending upon resistance applied; variable voltage regulators can be controlled by potentiometers (i.e.: volume control), so that you can turn a knob and get various voltages depending on where the knob is.
W
- Watt
X
- XLR Connector
- XTAL
- Short for crystal.
Y
Z
- Zener Diode
- Zero Crossing
