Alot of people just starting to look at pixels are wondering what you will need to get started. Well i hope this list will help out and get you going in the right direction.
List of things needed for pixels
- Pixel of your choice - Ie GECE, WS2801, 6801, 3005, RJ Smart Strings, Etc
- Controller of your choice that works with pixels you chose - Make sure it will work with your pixels
- Power supply - most strings are 5v but there are some 12v. Each pixel will use 60ma with full on white. So Each 50 pixels will use 3 amp. It is best to get one that is a little bigger than what you need to have some head room. ***Most pixels will need power re-injected after 50 pixels to make sure they work properly*** There are a lot of different types of power supplies you can choose from too. So it really comes down to what you want and what your looking to spend. The waterproof power supplies cost more but less headache since you don't have to worry about moisture getting to them. Also try to find a quality supply as some cheap knock offs might cause EMI.
- Sequencing Software - There are quite a few pieces of software out there now for Christmas lighting. Some are better than others. You will need try to find one that suites your needs. When using pixels your channel counts will go up dramatically. You need to make sure the software is easy to use with RGB channels.
- DMX Dongle - This is not necessary with all the controllers you choose. Some controllers use Ethernet/E1.31 which you will not need this dongle.
This is just the basic's you will need to start using pixels. Hope to add more information as time permits.
