LEDancer
General
The LEDancer (Le Dancer) is an inexpensive controller for up to 56 LEDs with a DMX512 input interface. The LEDs are connected together in a Charlie-Plexed common-cathode configuration. The design needs to use 2N3904 booster transistors for the LED cathodes to ensure that the low-level drive of the PIC is not exceeded, a configuration sometimes called chipi-plexing. The DMX address of the controller can be changed by shunting one of the PIC pins to ground and then sending a specially formatted DMX packet with the desires address.
PCB Schematic
PCB Design
At the moment there isn't a released PCB design. The design consists of a controller board (with a PIC16F1826 and a ST485 RS485 receiver, a jumper for enabling the DMX Address Program Mode, eight resistors and 8 2N3904 transistors, and some connectors.
Here is a proposed sample PCB design (note that it still needs caps next to the Voltage Regulator):
Connector Pinout
Jumper Identification
J1-Power
J2-DMX
J3-DMX
J4-ICSP Programming Header
J5 (2 pin)- DMX Address Programing
J5(8 Pin)- Output to LEDs
Unumbered 3 Pin- ???
BOM - Bill Of Materials
| 538-22-03-2021 | Headers & Wire Housings VERT PCB HDR 2P TIN PLATING | 2 |
| 538-22-03-2061 | Headers & Wire Housings VERT PCB HDR 6P TIN PLATING | 1 |
| 538-22-03-2031 | Headers & Wire Housings VERT PCB HDR 3P TIN PLATING | 3 |
| 80-C322C104K5R | Multilayer Ceramic Capacitors (MLCC) - Leaded 50volts 0.1uF 10% X7R | 1 |
| 80-C322C334M5U5CA | Multilayer Ceramic Capacitors (MLCC) - Leaded 50volts 0.33uF 20% Z5U | 1 |
| 299-82-RC | Carbon Film Resistors - Through Hole 82ohms 5% | 8 |
| 512-2N3904TA | Transistors Bipolar (BJT) NPN Transistor General Purpose | 8 |
| 511-ST485BN | Buffers & Line Drivers Hi-Spd Lo Pwr Trans | 1 |
| 579-PIC16F1826-I/P | Microcontrollers (MCU) 3.5KB Flash 256 byte 32 MHz Int. Osc | 1 |
| 571-1-390261-2 | IC & Component Sockets 8P ECONOMY TIN | 1 |
| 571-1-390261-5 | IC & Component Sockets 18P ECONOMY TIN | 1 |
| 604-WP7104GT | Standard LED - Through Hole GREEN TRANSPARENT | 1 |
| 299-330-RC | Carbon Film Resistors - Through Hole 330ohms 5% | 1 |
LEDs
In addition, you will need up to 56 White Piranha Style Super flux LEDs.  Other colors could be used, but you may need to adjust the resistor values on the controller board.
LED Segment PCBs
LED Connections
THIS SECTION IS OUT OF DATE.
Wirelist
Stackable LED Board Design
Assembly Instructions
THESE INSTRUCTIONS ARE NOT CORRECT, THEY ARE A WORK IN PROGRESS, PLEASE CHECK BACK IN A FEW DAYS
Assembly of the LEDancer is done in three steps:
- Assembly of the LEDancer Controller.
Begin by inspecting the PCBs to look for any defects such as cracks or breaks.  The holes on the board should be open on both sides.  Then inspect and sort out the various parts for the boards.
LEDancer Controller Assembly
- Install resistors
- Solder one 330 ohm resistor in R1 on top center of the PCB. The resistor is not polarized and can go either way. The 330 ohm resistor is optional and is only needed if you are installing the green LED on the controller board.
 - Solder eight 82 ohm resistors in R2-R9 on the right side of the PCB. The resistors are not polarized and can go either way.
 - Install IC sockets
- Solder one 8 pin IC socket on the left side of the PCB at U2. Install the socket with the notch facing to the right side of the PCB, matching the silkscreen.
 - Solder one 18 pin IC socket on the left side of the PCB at U3. Install the socket with the notch facing to the right side of the PCB, matching the silkscreen.
 - Install capacitors
- Solder one 0.1uf capacitor in C1 on the center left side of the PCB. The capacitor is not polarized and can go either way.
 - Solder one 0.33uf capacitor in C2 on the top left side of the PCB. The capacitor is not polarized and can go either way.The 0.33uf capacitor is optional and is only needed if the voltage regulator is installed.
 - Solder the eight 2N3904 transistors in Q1-Q8 on the right hand side of the PCB. The transistors are mounted with the flat side facing the top of the board matching the layout on the silkscreen.
 - Solder the green LED in D1 in the bottom center of the PCB. The LED is polarized and the long lead goes to the right side of the PCB.The green LED is optional and is currently not used by the firmware.
 - Install the headers.  The short end of the header is soldered into the PCB.
- Solder two 2 pin headers in J1 on the top left of the PCB and J5 in the top center of the PCB.
 - Solder three 3pin headers in J2 and J3 on the bottom left of the PCB and in the unmarked 3 position location in the top center of the PCB underneath where the silkscreen says U1 and R1.
 - Solder one 6 pin header J4 in the bottom center of the PCB.
 - Solder the voltage regulator in U1 on the top left side of the PCB. The voltage regulator is polarized and the heatsink side faces the top of the board.The voltage regulator is optional and is only needed if the power to the LEDancer is greater then 5V. If the LEDancer is powered by a regulated 5VDC power supply, you must omit the voltage regulator and install a wire jumper between the two outer pins of where the voltage regulator would go.
 - Install ICs
- Install the 18 pin PIC in U3 in the center of the board. The notch on the IC faces towards the right side of the board matching the silkscreen.
 - Install the 8 pin RS485 chip in U2 on the left side of the PCB. The notch on the IC faces towards the right side of the board matching the silkscreen.
LED Segment Board Assembly
Based on how long you are making the LEDancer, you will need to assemble 1-4 LED Segment boards.
1. Solder the fourteen Superflux LEDs to the LED Segment PCB.  The LEDs are polarized, there is one corner that is cut off and not square.  The LED must be installed so that the orientation of the notched corner matches the silkscreen.  If you are using the LEDs sold in the Fall2011 group buy, they are inserted with the notched corner matching the silkscreen.   WARNING, Some LEDs from other vendors may have different orientations and they may need to be rotated 180 degrees from the silkscreen drawing.  Please check to make sure know the  correct orientation for your LEDs before soldering them to the PCB.  The correct orientation of the LEDs would be to have the two cathode(-) pins of the LED in inserted in the two  left side holes in the PCB.
2.  Repeat Step #1 for each of your LED Segment PCBs.
3.  The LED Segment PCBs need to be interconnected to make them the desired length.  This is done by aligning the Input holes of one PCB with the Output holes of the next board.  To do this lay one board on top of the next and carefully align the Input and Output Holes.  You need to solder eight jumpers through these holes to each of the PCBs.  Short lengths or wire or cutoff leads from resistors or other components work great.
4.  Repeat Step #3 until you have the correct number of LED Segment PCBs connected.
Final Assembly
1.  Solder the wires from the LEDancer Controller to the Input of the top LED Segment PCB.  The #1 wire on the controller side is near the top of the board and has a square hole.  It is soldered to the top left hole of the Input of the top LED Segment PCB, which is marked by the number 1 near the top of the board.  The holes on the LED Segment board are offset into two columns, which are odd and even.  So the #2 wire from the LEDancer Controller goes into the first hole in right column slightly below and to the right of where you soldered in the first wire. The #3 wire goes in the hole directly below the #1 wire in the left column.  The #4 wire goes below the #2 wire.  Continue until you have soldered in all eight wires.  It is important that the correct holes on the controller and the segment boards are connected properly.
2.  Inspect all of the PCBs to make sure that there are no issues with the soldering.
3.  Insert the PIC into the socket on the LEDancer Controller
4.  Apply 5vdc to the power input of the LEDancer Controller and the LEDS should begin to light and fall.
5.  The LEDancer Controller should be placed behind the top LED Segment PCB with some cardboard between the board to prevent them from shorting out.  This assembly can then slide into the plastic housing.
6.  Apply the end caps and seal the tube to prevent rain from entering.
Congratulations, you have finished constructing your LEDancer.
PIC Program
Programming the DMX Address
