Simple Renard RGB+W
Simple Renard RGB+W Parts
Part | Description | Mouser PN | Qty |
P1 | Fixed Terminal Blocks 5.08MM VERTICAL 2P wire protector | 571-7969492 | 2 |
C1,C2 | Aluminum Electrolytic Capacitors - Leaded 35volts 47uF 5x11 20% 2LS | 647-UVZ1V470MDD | 2 |
C6 | Multilayer Ceramic Capacitors (MLCC) - Leaded 0.33uF 50volts X7R 10% | 81-RDER71H334K1K103B | 1 |
C3,C4,C5 | Multilayer Ceramic Capacitors (MLCC) - Leaded 0.1uF 50volts Y5V +80-20% 2.5mm L/S | 81-RPEF51104Z2S2A03A | 3 |
D1 | Zener Diodes 4.3 Volt 0.5 Watt) | 78-1N5229B | 1 |
D2 | Zener Diodes 9.1 Volt 0.5 Watt) | 78-1N5239B | 1 |
IC1 | RS-485 Interface IC LP Diff Pairs | 595-SN65LBC179P | 1 |
IC3 | Linear Regulators - Standard 1A Pos Vol Reg | 512-LM7805CT | 1 |
IC & Component Sockets 40P DUAL WIPE DIPSKT | 517-4840-6000-CP | 1 | |
IC5 | Microcontrollers (MCU) 32KB 1536 RAM 36I/O | 579-PIC18F4520-I/P | 1 |
ICSP | Headers & Wire Housings FLAT HEADER 6P Straight Post tinr | 571-6404526 | 1 |
JP2 XBee header | Headers & Wire Housings FLAT HEADER 5P Straight Post tin | 571-640452-5 | 1 |
Shunt for XBheader and Vreg bypass | Headers & Wire Housings Mini Shunt .177" height | 737-MSC-G | 3 |
JP3 Vreg bypass | Headers & Wire Housings FLAT HEADER 2P Straight Post tin | 571-6404522 | 1 |
J1-J10 | Ethernet & Telecom Connectors 8 PCB LO PRO R/A | 571-5555164-1 | 10 |
Status Led | Standard LED - Through Hole YELLOW DIFFUSED | 604-WP132XYD | 1 |
Power Led | Standard LED - Through Hole RED DIFFUSED | 604-WP132XID | 1 |
RX/TX Led | Standard LED - Through Hole GREEN DIFFUSED | 604-WP132XGD | 1 |
R1,R2,R6 | Carbon Film Resistors - Through Hole 1.0Kohms 0.05 | 299-1k-RC | 3 |
R3,R7 | Carbon Film Resistors - Through Hole 330ohms 5% | 299-330-RC | 2 |
R4 | Carbon Film Resistors - Through Hole 10Kohms 5% | 299-10k-RC | 1 |
R5 | Carbon Film Resistors - Through Hole 120ohms 0.05 | 299-120-RC | 1 |
R9,R10 | Carbon Film Resistors - Through Hole 27Kohms 5% | 299-27k-RC | 2 |
R11-42 | Carbon Film Resistors - Through Hole 820ohms 5% | 299-820-RC | 32 |
T1-32 | Transistors Bipolar (BJT) 600mA 75V NPN | 863-PN2222AG | 32 |
PIC Bypass | Headers & Wire Housings NARROW FLT HDR 3P Straight Post | 571-3-644456-3 | 1 |
IC & Component Sockets 8P DUAL WIPE DIPSKT | 517-4808-3004-CP | 1 |
Housing
Building the Simple Renard RGB+w
- Install the resistors:
- Install the capacitors:
- Install the IC socket:
- Install the transistors:
- Install the 5v linear regulator
Final Testing
Mounting in Housing
Jumper Settings / Headers
JP1 ??
JP2 XBee Header
Pin Layout
- +5VDC
- N/C
- GND
- RX from 485 chip
- RX in to PIC
JP3- 5V Bypass
Only install JP3 if you have omitted C1 and IC3 if V+ is +5VDC and well regulated
JP4 ??
ICSP
Use for programing PIC on the circuit board.
Connecting up the Simple Renard RGB+w
Pin 1 - Pin 2 - Pin 3 - Pin 4 - Pin 5 - Pin 6 - Pin 7 - Pin 8 -
PCB
Design Options
