Simple Renard RGB+W
Simple Renard RGB+W Parts
| P1 | Fixed Terminal Blocks 5.08MM VERTICAL 2P wire protector | 571-7969492 | 2 |
| C1,C2 | Aluminum Electrolytic Capacitors - Leaded 35volts 47uF 5x11 20% 2LS | 647-UVZ1V470MDD | 2 |
| C6 | Multilayer Ceramic Capacitors (MLCC) - Leaded 0.33uF 50volts X7R 10% | 81-RDER71H334K1K103B | 1 |
| D1 | Zener Diodes 4.3 Volt 0.5 Watt) | 78-1N5229B | 1 |
| D2 | Zener Diodes 9.1 Volt 0.5 Watt) | 78-1N5239B | 1 |
| IC1 | RS-485 Interface IC LP Diff Pairs | 595-SN65LBC179P | 1 |
| IC3 | Linear Regulators - Standard 1A Pos Vol Reg | 512-LM7805CT | 1 |
| IC5 | Microcontrollers (MCU) 32KB 1536 RAM 36I/O | 579-PIC18F4520-I/P | 1 |
| JP2 XBee header | Headers & Wire Housings FLAT HEADER 5P Straight Post tin | 571-640452-5 | 1 |
| Shunt for XBheader and Vreg bypass | Headers & Wire Housings Mini Shunt .177" height | 737-MSC-G | 3 |
| JP3 Vreg bypass | Headers & Wire Housings FLAT HEADER 2P Straight Post tin | 571-6404522 | 1 |
| R1,R2,R6 | Carbon Film Resistors - Through Hole 1.0Kohms 0.05 | 299-1k-RC | 3 |
| R3,R7 | Carbon Film Resistors - Through Hole 330ohms 5% | 299-330-RC | 2 |
| R4 | Carbon Film Resistors - Through Hole 10Kohms 5% | 299-10k-RC | 1 |
| R5 | Carbon Film Resistors - Through Hole 120ohms 0.05 | 299-120-RC | 1 |
| R9,R10 | Carbon Film Resistors - Through Hole 27Kohms 5% | 299-27k-RC | 2 |
| R11-42 | Carbon Film Resistors - Through Hole 820ohms 5% | 299-820-RC | 32 |
| T1-32 | Transistors Bipolar (BJT) 600mA 75V NPN | 863-PN2222AG | 32 |
| IC & Component Sockets 8P DUAL WIPE DIPSKT | 517-4808-3004-CP | 1 |
Housing
- Install the resistors:
- Install the capacitors:
- Install the IC sockets:
- Install the diodes:
- Install the transistors:
- Install the headers:
- Install the 5v linear regulator
- Install the RJ45 jacks:
- Install the terminal strips:
- Install the ICs:
- Install the jumpers:
Final Testing
Mounting in Housing
Jumper Settings / Headers
JP1 PIC Option
Currently unused. Normal position is no jumper.
JP2 XBee Header
Pin Layout
1 +5VDC
2 N/C
3 GND
4 RX from 485 chip
5 RX in to PIC
If you are not using a XBee Wireless module place a jumper across pins 4/5.
JP3- Vreg Bypass
Only install jumper on JP3 if you have omitted C1 and IC3 if V+ is +5VDC and well regulated!
JP4 PIC Bypass
Normal position is jumper across pins 2/3.
ICSP
Use for programing PIC on the circuit board.
Data
Outputs
J3 is Output channels 1-4
J4 is Output channels 5-8
J5 is Output channels 9-12
J6 is Output channels 13-16
J7 is Output channels 17-20
J8 is Output channels 21-24
J9 is Output channels 25-28
J10 is Output channels 29-32
Pin 1 - V+ Pin 2 - Channel 1 Output Pin 3 - V+ Pin 4 - Channel 2 Output Pin 5 - V+ Pin 6 - Channel 3 Output Pin 7 - V+ Pin 8 - Channel 4 Output
Power
PCB
Design Options
