SSRneon-G2-LED
The SSRneon is a 4 port AC Solid State Relay (SSR). It is derived from the same basic design that has been in general use by the DIY community for many years. Most of the DIY SSRs are derived from Sean Bowf's original 4 port SSR.  The design has evolved over the years, but the core functions and parts are the same. The SSRneon, SSRoz and SSRez are all such designs.
The current Versions of the SSRneon are SSRneon-G2 and SSRneon-G12-LED.
Safety Features
Three key points are what differentiates the SSRneon-G2-LED from the other available SSRs.
The SSRneon-G2-LED haskey points are what differentiates the SSRneon-G2-LED from the other available SSRs.
The SSRneon-G2-LED has two key features not present in the SSRneon-G2:
1.  The 2 ounce copper AC traces are mirrored on both sides of the board.  This allows for greater current carrying capacity. (8 amps)
2.  There are LED channel indicators.  These LEDs will flash and dim in the same manner as the lights that are hooked to the SSR.
Order your own boards
Home Etch
If you want to home etch an SSR, please go to the wiki entry for the SSRneon-G2 which is a home etch friendly design.
Fuse Rating
The SSRneon-G2 has the largest combination of trace sizes and copper weight of any of the DIY SSRs to date. (6/17/2011) With that said, a Fuse of 4 amps is a good place to start. If you want to drive more then 1 amp through any individual TRIAC (channel), then you can ramp up to as high as a 8 amp fuse. However, once you move above 1 amp through any single TRIAC (channel), you should put a heat sink on the TRIAC(s). This does not mean you can run 8 amps through a single TRIAC (channel). A single TRIAC can handle 2.0 amps max. You will notice that the copper traces that connect to any one TRIAC are no where near the size of the main AC copper trace. So, just because the TRIAC you use may be rated for 3 or 4 or more amps doesn't mean the SSRneon-G2-LED can safely drive it at that amperage.
BOM for 120VAC Operation:
4      571-1-390261-1     IC Sockets 6P ECONOMY TIN  (Optional, but worth every penny)
                          also marked U1, U2, U3 and U4
5      571-2828372        Terminal Blocks 5.08MM PCB MOUNT 2P
See above for TA-200 sources.
240VAC Operation
FireGod
