SSRneon-G2-LED
![Version G2](/wiki/images/e/ec/Ssrneon_pcb.jpg)
Safety Features
![ne-2E](/wiki/images/9/97/Ne-2e_picture.jpg)
![Neon glow.jpg](/wiki/images/f/f1/Neon_glow.jpg)
Neons are used instead of an incandescent bulbs due to the fact that a neon bulb is very long lived and is much 'tougher' then an incandescent since there is no filament to break.
![small](/wiki/images/e/e7/SSRneon_G2_LED_smaller.jpg)
![TA-200](/wiki/images/7/7f/TA-200.jpg)
![terminal block](/wiki/images/8/86/Terminal_block.jpg)
The Schematic can be viewed by clicking by clicking on this link:
SSRneon-G2-LED Schematic
Order your own boards
Home Etch
If you want to home etch an SSR, please go to the wiki entry for the SSRneon-G2 which is a home etch friendly design.
Fuse Rating
![fuse](/wiki/images/2/25/Fuse.jpg)
BOM for 120VAC Operation:
QTY Mouser #: Description 2 606-A9A Neon Lamp 65VAC .7mA NE-2E marked NE1, NE2 1 571-5556416-1 Modular Jacks 8 PCB TOP ENTRY marked J1 4 511-BTA04-700T Triacs 4 Amp 700 Volt marked U1, U2, U3, and U4 2 534-3517 Fuse Clips and Holders PC FUSE CLIP 5 MM 1 534-3527C Fuse Cover 5 604-WP7104IT LED Standard HI EFF RED TRANS marked LED1, LED2, LED3, LED4, LED5 1 660-CF1/4C681J 1/4Watt Axial Carbon Film Resistors 680ohms 5% marked R9 4 660-CF1/4C221J 1/4Watt Axial Carbon Film Resistors 220ohms 5% marked R1, R2, R3, R4 4 660-CF1/4C181J 1/4Watt Axial Carbon Film Resistors 180ohms 5% marked R5, R6, R7 & R8 2 660-CF1/4C104J 1/4Watt Axial Carbon Film Resistors 100Kohms 5% marked R10, R11 4 859-MOC3023 Optocomponents Optocoupler marked IC1, IC2, IC3 and IC4 4 571-1-390261-1 IC Sockets 6P ECONOMY TIN marked IC1, IC2, IC3, IC4 5 571-2828372 Terminal Blocks 5.08MM PCB MOUNT 2P marked TB1, TB2, TB3, TB4, TB5 Note regarding resistors. You usually want to purchase resistors from Mouser in quantities of 100 of a specific value. You usually can get 100 resistors for the same price of 20 individual resistors. (You will eventually use them !) As noted above in the FUSE Section, you have a choice to make. You only need one fuse per SSRneon. You should always order extra fuses. 1 504-GMC-2 5mm x 20mm Medium Time Delay Fuses 125VAC 2A Med Time Delay 1 504-GMC-3 5mm x 20mm Medium Time Delay Fuses 125VAC 3A Med Time Delay 1 504-GMC-4 5mm x 20mm Medium Time Delay Fuses 125VAC 4A Med Time Delay 1 504-GMC-5 5mm x 20mm Medium Time Delay Fuses 125VAC 5A Med Time Delay 1 504-GMC-6 5mm x 20mm Medium Time Delay Fuses 125VAC 6A Med Time Delay 1 504-GMC-7 5mm x 20mm Medium Time Delay Fuses 125VAC 7A Med Time Delay 1 504-GMC-8 5mm x 20mm Medium Time Delay Fuses 125VAC 8A Med Time Delay The following items are NOT available from Mouser. You can get everything but the TA-200 from your local hardware store or home center. See above for TA-200 sources. 2 Screw,#8x1/2" Pan Head Sheet Metal (You can use the screws that come with the TA-200 if you cut them down) 1 TA-200 Enclosure 1 Male Plug Power Cord, Rated for 8A Minimum 4 Female Plug Power Cord, Rated for 4A Minimum The power cords are often fashioned from standard household extension cords with one of the ends cut off. You can also make your own with SPT wire and 'vampire' plugs/receptacles.
Wiring The SSRneon
Controller Output Pinout
![Version G2](/wiki/images/1/14/Ssrneon_001.jpg)
