Revision as of 21:47, 23 August 2012 by Jklingert (talk | contribs) (Software)
What is the TIR Flood?
Manufacturer's Description
How does the TIR Flood work?
Dimensions of the TIR Flood
TIR Flood Components
Connectors
Housing
LED Assembly
Control Module
There is a control module that drives the LEDs and responds to the DMX commands provided to it thru the DMX interface. The Control Module is mounted inside a waterproof housing and is attached to the rear heatsink with a generous amount of heatsink compound. Inside of the Control Module there are some HEXFETs that appear to be driving the LEDs (IRL510S). There's a LM2676 5V regulator nearby some of these. The only large chip on the board is on the backside - has a LDT logo on it, with a LD71D1048C designation.
Ethernet Module
Power Supply
The power supply is a 100-240 VAC input and 24.5VDC 3.3A output. The power supply is sealed in a waterproof enclosure and the wires come through the enclosure via waterproof sealing glands. The power supply has an input power cord on one end and has a red and black 16ga wire on the other end that connects to the control housing. Midway between the power supply and the control housing there is black shrink wrap on the red and black power leads. If you carefully remove the heat shrink, you will find blue "bullet" type connectors that can be separated by pulling them apart.
Mounting Bracket
Disassembling the TIR Flood
Main Body Separation
  1. Remove the 3 screws near the rounded back edge on both side panels near the bracket attachment.
  2. Loosen the four screws that hold the black plastic housing and base plate to the light housing. Wear gloves, there is a lot of thermal heat sink compound behind the base plate.
  3. Turn the module over and remove the screws that hold the base plate to the black plastic housing.
  4. Gently pry the black plastic housing from the base plate with a flat edge screwdriver, it is held in place by a sealant/gasket.
TIR Flood Power Requirements
AC Power Cable
ConductorWire Color
LineBrown
NeutralBlue
GroundGreen/Yellow
Controlling the TIR Flood
DMX Wire / XLR Connector
SignalWire ColorXLR Pin
DMX IN ShieldRed Foil1
DMX IN +Red Wire in Red Foil3
DMX OUT ShieldGreen FoilNC
DMX OUT +Red Wire in Green FoilNC
Internal Wiring Color Codes
LED ConnectionWire Color
Common (+)Red/Green
REDRed/Black
GREENWhite/Black
BLUEGreen/Black
Upper section
Common (+)Black/Red
REDWhite
GREENBlack
BLUERed
Lower section
Common (+)Orange/Red
REDOrange
GREENGreen
BLUEBlue
Thermistor
LED Connector
Pin NumberWire Color
1White
2Green
3Blue
4Red/Black
5Orange/Black
6Black/White
7Green/White
8Black/Red
9Orange/Red
10Red/Green
11Black/Red/White
12Red/Black/White
13Black
14Red
15Orange
16White/Black
17Green/Black
18Blue/Black
19Red/White
20Blue/White
21White/Red
22Blue/Red
23Thermistor \
Replacement Power Supplies
Replacement Control Modules
DMX Address Translation Board
Documentation
Destiny CG Wiring Schematic
Destiny CG Datasheet
Software
Light Management
Light Initilization
Light Design and Emulation
Netburner
IP Setup tool
UDP Terminal Application
TIR Flood Discussion Threads
Initial Thread
TIR Breakout board
Test Pattern
Outdoor Test
Another outdoor test
Other Photos
