Enclosures
Enclosures
THIS PAGE IS UNDER CONSTRUCTION AND HAS NOT BEEN CHECKED FOR ERRORS!!!
Typical Enclosures
TA-200 (Terminal Access TA-200 Terminal Enclosure)
Common usage: SSRez ACSSR,  SSRNeon ACSSR,  DCSSR Version 2.4
External Dimensions (HxWxD):  3.13” x 3.63” x 2.5” (7.95cm x 9.22cm x 6.35cm)
Internal Dimensions:
Datasheet
Internal Drawing
CG-500
Common usage: Simple Renard 32 Combo,  Simple Renard 32 RGB+W DC Controller
External Dimensions (HxWxD):  6.5" x 8.0" x 2.75" (16.5cm x 20.3cm x 7.0cm)
Datasheet
Internal Drawing
CG-1000
Common usage: Renard SS8 AC Controller,  Renard SS16 AC Controller,  Renard 48LSD DC Controller,  Ren64 Controller
External Dimensions (HxWxD):  9.00" x 9.00" x 3.00" (22.80cm x 22.80cm x 7.60cm)
Datasheet
Internal Drawing
CG-1500
Common usage:
External Dimensions (HxWxD): 12.25" x 12" x 5.25" (31.10cm x 30.50cm x 13.30cm)
Datasheet
Internal Drawing
CG-2000
Common usage:  Renard SS 24
External Dimensions (HxWxD):  13.0" x 9.0" x 3.0" (33.00cm x 22.80cm x 7.60cm)
Datasheet
Internal Drawing
Mounting Options
Vendors
