Ohm's Law
Ohm's Law
Ohm's Law is a formula that relates the basic electrical properties. These properties can be measured with a multimeter.
- V=IR
- V=IR
Ohm's Law Diagram
Voltage (V)
Voltage is measured in volts (V). Voltage is a measure of the electric potential difference between two points. There are two basic type of voltage:
- AC Alternating Current
- Example:
- Example:
- DC Direct Current
- Example:
- Many Integrated Circuits require 5 volts DC (VDC) to power them.
- Example:
Current (I)
- Example:
Resistance (R)
- Example:
Power (P)
Power is measured in watts (W). Electric power is a measure of the rate of doing work. The common formula for Power is:
- P=VI
- Power=Voltage x Current
- P=VI
- Example:
LED Calculator
Use these calculators to calculate the resistor needed to include in a circuit with a LED.
Single LED
LED Calculator for 1 LED.
Array of LEDs
LED Calculator for an array of LEDs.
