Different Styles of Pixels
Revision as of 18:56, 4 January 2013 by Jklingert (talk | contribs) (Ray Wu)
Pixel Properties
Form Factor
  • Strings (Can be any length, but more then 50 pixels will require power injection)
    1. 12mm pixel nodes
  • Strips (Usually 5M length)
    1. Bare board (no waterproofing)
    2. Hollow Tube
    3. Solid Tube
      • Solid Silicone
      • Solid Epoxy Resin
  • Modules
    1. Square
    2. Rectangular
LEDs per meter
  • Strips
    1. 30 LED/m
    2. 60 LED/m
  • Strings
    1. 10 LED/m (100mm spacing between nodes is common )
Power Supply Voltage
    1. 5VDC
    2. 12VDC
    3. 24VDC
LED Type
    1. 3528 surface mount (3.5mm x 2.8mm) (typically used in strips and modules)
    2. 5050 surface mount (5.0mm x 5.0mm) (typically used in strips and modules)
    3. 8mm (typically used in strings)
Waterproofing
    1. Injection Molded Silicone
    2. Epoxy Resin coated PCB in Silicone
    3. Cast Epoxy Resin in Sleeve
    4. Cast Epoxy Resin coated PCB
Wire Size
    1. 18 Gauge wire (Thicker, better for longer distance or more pixels)
    2. 20 Guage wire
      • LPD8806
      • LPD8809
      • WS2801 - 4 wire (can drive 3 channels, or 1 RGB LED)
      • WS2803 - 4 wire (can drive 18 channels, or 6 RGB LED)
      • WS2811 - 3 wire (can drive 3 channels, or 1 RGB LED)
      • TM1803 - 3 wire (can drive 3 channels, or 1 RGB LED) Datasheet (English)
      • TM1804 - 3 wire (can drive 3 channels, or 1 RGB LED)
      • TM1809 - 3 wire (can drive 9 channels, or 3 RGB LEDs) Datasheet (English)
      • TM1812 (can drive 12 channels, or 4 RGB LEDs)
      • SM16715
      • SM16716
      • P9813 - 4 wire
      • P9816 - 4 wire
      • HX512A (Native DMX) Datasheet Chinese
      • MY9941 (Native DMX)
      • MY9942 (Native DMX)
      • MY9943 (Native DMX)
DIYLEDEXPRESS
Form Factor IC Length Voltage LEDs per Meter ICs per meter Link Image Note
String WS2801 50 pixels (6m) 5vdc 10 10 link IP68
String WS2811 50 pixels (6m) 5vdc 10 10 link IP68
String (Square) WS2811 50 pixels (6m) 12vdc 10 10 link IP68
Module (Rectangular) WS2811 20 pixels (2m) 12vdc 10 10 link
Strip WS2811 50 pixels (5m) 5vdc 30 10 link Silicone Tube
Strip WS2811 100 pixels (5m) 5vdc 60 20 link Silicone Tube
Strip TM1809 150 Pixels (5m) 12vdc 30 10 link Silicone Tube
Ray Wu
String WS2801 50 pixels (5m) 5vdc 10 10 link IP68
String WS2801 50 pixels (5m) 5vdc 10 10 link IP68, with faceted C9 cover
String WS2801 100 pixels (10m) 12vdc 10 10 link IP68
String (square) WS2801 50 pixels (5m) 5vdc 10 10 link IP68
String (square) WS2801 50 pixels (5m) 5vdc 10 10 link IP66, side wire
String (square) WS2801 50 pixels (5m) 5vdc 10 10 link IP68, with faceted C9 cover
Strip WS2801 160 pixels (5m) 5vdc 32 32 link IP65, silicone tube
Strip WS2801 60 pixels (5m) 12vdc 36 12 link IP65, silicone tube
Module (square) WS2801 20 pixels 12vdc 40 10 link
String WS2811 50 pixels (5m) 5vdc 10 10 link IP68
String WS2811 50 pixels (5m) 5vdc 10 10 link IP66, with 4 pin waterproof connectors
String (square) WS2811 50 pixels (5m) 5vdc 10 10 link IP68
String (square) WS2811 100 pixels (10m) 12vdc 10 10 link IP66, side wire
Strip WS2811 150 pixels (5m) 5vdc 30 30 link Silicone tube
Strip WS2811 240 pixels (4m) 5vdc 60 60 link Silicone tube
Module (rectangular) WS2811 20 pixels 12vdc 30 10 link
TBD TBD TBD TBD TBD TBD TBD
Stellascapes
String (Stella-green) WS2801 85 pixels 5vdc 10 10 link
String (Stella-black) WS2801 42 or 85 pixels 5vdc 10 10 link
