16 Channel Renard with SSR Assembly Instructions
- Assembly Time: 2 hours
- Skill Level: Medium
Disclaimer
THIS FILE IS DISTRIBUTED IN THE HOPE THAT IT WILL BE USEFUL, BUT WITHOUT ANY WARRANTY; WITHOUT EVEN THE IMPLIED WARRANTY OF MERCHANTABILITY OR FITNESS FOR A PARTICULAR PURPOSE.
Reference Material
Tools
- Bench Soldering Iron
- Silver Solder
- Flat cut dykes
- Desoldering bulb
Other Requirements
- You will need an RS232 to RS485 converter. I would suggest EBAY
Related Documents/Links
- RS485 Converter from Ebay
- Parts List
- Theory of Operations
- Image of Board
- Top of PCB
- Botton of PCB
- Silk Screen
- Latest PIC Code
Build Steps
Install Item | Qty | Mouser P/N | Location | Notes |
1. IC sockets 6 pin | 17 | 571-3902611 | U3-U19 | Make sure they are oriented the same way as the silk screen image. U19 is oriented opposite of the others. |
2. IC Sockets 8 Pin | 2 | 575-193308 | U20 & U21 | . |
3. IC Sockets 14 Pin | 2 | 575-199314 | U1 & U2 | . |
4. Bossman Fuse Holder | 4 | 504-1a3399-10 | H1 & H2 pads | Make sure the notch on the fuse holder is oriented so one is on the top and the other on the bottom to properly hold the fuse. |
5. Euro Sytle Terminal Blocks | 11 | 538-398890-0302 | Lower Edge of Board | . |
6. 15Kohm resistors | 2 | 71-ccf60-15k-e3 | R17 & R18 | . |
7. 178ohm resistors | 16 | 273-178-rc | R1 - R16 | Orient the colored bands all the same way for ease of troubleshooting later. |
8. 10pin 680ohm bus resistor | 2 | 266-680 | above U7 & U15 | . |
Numbered Photo - Numbers coorospond to the build steps | ||||
9. 2 ping jumper mount | 4 | 571-3-644456-2 | J1 - J4 | . |
10. Green LED | 2 | 604-wp7104gt | Ch2Diag #1 & #2 | The short leg of the led goes to the flat side of the silkscreening |
11. Monolithic Radial Capactor | 2 | 81-rpee41h105m4k1e12 | C1 & C2 | . |
12. Amp Modular Jacks rj45 | 2 | 571-5520251-4 | Upper Right and Left | . |
13. Coated axial ceramic capacitors | 2 | 80-c410c104m5u | C3 & C4 | . |
14. Voltage Regulator | 1 | 821-TS7805C2 | 5vReg | . |
15. 8 amp Triac | 16 | 511-BTA08-400b | Bottom of board | Be sure to solder these well as they will be carrying 110v A/C |
16. 1K ohm resistors | 3 | 660-mf1/4dc1001f | R20, R21 & R24 | . |
17. Crystal Clock oscillator | 1 | 520-tck1843-x | OSC1 | . |
18. 22k ohm resistor | 3 | 660-mf1/4dlt52r2702f | R19, R22 & R23 | . |
19. zener diod | 1 | 78-in5239b | D2 | . |
20. zener diode | 1 | 512-1n5229b-t50a | D1 | . |
21. 120 ohm resistor | 1 | 660-mf1/4dct52r1200f | R26 | . |
22. VR/50v diod | 1 | 625-1n4001-e3 | D3 | . |
23. red led | 1 | 604-wp7104ec | Top Center | . |
24. H11aa1 | 1 | 782-h11aa1 | U19 | . |
25. Rs485 | 2 | 837-isl81487eip | U20 & U21 | . |
26. Pic Chips | 2 | 11-11 | #2 | . |
27. fuses | 2 | 504-gma-5 | H1 & H2 | . |
28. Heat Sync | 1 | 532-574502B00 | 5vReg | . |
Still Entering Give me so time to finish before you edit this please
Options
240 volt Conversion
The original controller was designed for operation on 110VAC and many of the parts were specified for 110V. The board will operate at other voltages, however a number of changes need to be made.
The first decision to be made is what voltage you want to switch. The triacs are responsible for switching the primary voltage. The is no reason that the primary voltage for the TRIACs could not be 240VAC or 24VAC, however the circuit will need to be modified.
For this example, I'll modify the board for 24VAC switching.
Parts Required and changes.
Gate Resistors - The original value for the gate resistors (item 7) was 180 ohms. For 24VAC operation, the gate resistors need to be changed to 33 ohms.
