Different Styles of Pixels
Pixel Properties
Form Factor
- Strips (Usually 5M length)
- Modules
LEDs per meter
- Strips
- 30 LED/m
- 60 LED/m
- Strings
Power Supply Voltage
- 5VDC
- 12VDC
- 24VDC
LED Type
Waterproofing
Wire Size
- 20 Guage wire
- LPD1101
- UCS6909
- UCS6912
- LPD8806
- LPD8809
- SM16715
- SM16716 -4 wire (can drive 3 channels, or 1 RGB LED) Datasheet (Chinese)
- P9813 - 4 wire
- P9816 - 4 wire
- TLS3002
- CYT3001
- CYT3005 - 3 wire
- MY9941 (Native DMX)
- MY9942 (Native DMX)
- MY9943 (Native DMX)
DIYLEDEXPRESS
Form Factor | IC | Length | Voltage | LEDs per Meter | ICs per meter | Link | Image | Price | Price per Pixel | Note |
String | WS2801 | 50 pixels (6m) | 5vdc | 10 | 10 | link | $26.00 | $0.52 | IP68 | |
String | WS2811 | 50 pixels (6m) | 5vdc | 10 | 10 | link | $24.25 | $0.49 | IP68 | |
String (Square) | WS2811 | 50 pixels (6m) | 12vdc | 10 | 10 | link | $25.75 | $0.52 | IP68, back wire | |
Module (Rectangular) | WS2811 | 20 pixels (2m) | 12vdc | 10 | 10 | link | $16.75 | $0.84 | 3 LEDs | |
Strip | WS2811 | 50 pixels (5m) | 5vdc | 30 | 10 | link | $42.50 | $0.85 | silicone tube | |
Strip | WS2811 | 100 pixels (5m) | 5vdc | 60 | 20 | link | $65.00 | $0.65 | silicone tube | |
Strip | TM1809 | 150 Pixels (5m) | 12vdc | 30 | 10 | link | $60.00 | $0.40 | silicone tube |
Light-O-Rama (LOR)
(USA Based)
String | LPD6803 | 100 pixels (15.25m) | TBDvdc | 6.5 | 6.5 | link | $239.95 | $2.40 | Cosmic Color Pixels (with controller and Power Supply) | |
Bulbs | LPD6803 | 100 pixels (15.25m) | TBDvdc | 6.5 | 6.5 | link | $289.95 | $2.90 | Cosmic Color Bulbs (with controller and Power Supply) | |
Strip | LPD6803 | 50 pixels (5m) | TBDvdc | 30 | 10 | link | $249.95 | $2.50 | Cosmic Color Ribbon (with controller and Power Supply) |
Ray Wu
(China Based)
Form Factor | IC | Length | Voltage | LEDs per Meter | ICs per meter | Link | Image | Note |
String | WS2801 | 50 pixels (5m) | 5vdc | 10 | 10 | link | IP68 | |
String | WS2801 | 50 pixels (5m) | 5vdc | 10 | 10 | link | IP68, with faceted C9 cover | |
String | WS2801 | 100 pixels (10m) | 12vdc | 10 | 10 | link | IP68 | |
String (square) | WS2801 | 50 pixels (5m) | 5vdc | 10 | 10 | link | IP68, back wire | |
String (square) | WS2801 | 50 pixels (5m) | 5vdc | 10 | 10 | link | IP66, side wire | |
String (square) | WS2801 | 50 pixels (5m) | 5vdc | 10 | 10 | link | IP68, with faceted C9 cover | |
Strip | WS2801 | 160 pixels (5m) | 5vdc | 32 | 32 | link | IP65, silicone tube | |
Strip | WS2801 | 60 pixels (5m) | 12vdc | 36 | 12 | link | IP65, silicone tube | |
Module (square) | WS2801 | 20 pixels | 12vdc | 40 | 10 | link | ||
String | WS2811 | 50 pixels (5m) | 5vdc | 10 | 10 | link | IP68 | |
String | WS2811 | 50 pixels (5m) | 5vdc | 10 | 10 | link | IP66, with 4 pin waterproof connectors | |
String (square) | WS2811 | 50 pixels (5m) | 5vdc | 10 | 10 | link | IP68, back wire | |
String (square) | WS2811 | 100 pixels (10m) | 12vdc | 10 | 10 | link | IP66, side wire | |
Strip | WS2811 | 150 pixels (5m) | 5vdc | 30 | 30 | link | silicone tube | |
Module (rectangular) | WS2811 | 20 pixels | 12vdc | 30 | 10 | link | ||
Strip | WS2812 | 240 pixels (4m) | 5vdc | 60 | 60 | link | silicone tube, WS2811 with integrated 5050 LED | |
String | LPD6803 | 50 Pixels (5m) | 5vdc | 10 | 10 | link | IP68 | |
String (square) | LPD6803 | 50 Pixels (5m) | 5vdc | 10 | 10 | link | IP68, side wire | |
Strip | LPD6803 | 50 Pixels (5m) | 12vdc | 30 | 10 | link | IP68, similar to LOR CCR | |
Module (square) | LPD6803 | 20 pixels (2m) | 12vdc | 10 | 10 | link | 3 LEDs | |
Module (rectangular) | LPD6803 | 20 pixels (2m) | 12vdc | 10 | 10 | link | 3 LEDs | |
String | TLS3001 | 50 pixels (5m) | 5vdc | 10 | 10 | link | IP68 | |
String | TLS3001 | 50 pixels (5m) | 5vdc | 10 | 10 | link | IP68, with 4 pin waterproof connectors | |
String (square) | TLS3001 | 50 pixels (5m) | 5vdc | 10 | 10 | link | IP68, back wire | |
Strip | TM1809 | 150 pixels (5m) | 12vdc | 30 | 10 | link | IP67, silicone tube | |
Strip | TM1809 | 150 pixels (5m) | 12vdc | 30 | 10 | link | IP65, silicone coating | |
Strip | TM1809 | 240 pixels (5m) | 12vdc | 48 | 16 | link | IP68, silicone tube |
Retail Store (i.e. Lowes)
String | GECE | 25,36,50 pixels (20,29,41ft) | 5vdc | 4 | 4 | link | G35 Cover, General Electric Color Effects |
Seasonal Entertainment
String | WS2801 | 42 pixels (4.2m) | 12vdc | 10 | 10 | link | $32.00 | $0.76 | IP68, Rainbow Mini Pixels | |
String (square) | WS2801 | 42 pixels (8.4m) | 12vdc | 5 | 5 | link | $43.00 | $1.02 | IP68, Rainbow C7 Pixels | |
String (square) | WS2801 | 42 pixels (8.4m) | 12vdc | 5 | 5 | link | $45.00 | $1.07 | IP68, Rainbow C9 Pixels | |
Strip | WS2801 | 42 pixels (4.2m) | 12vdc | 30 | 10 | link | $73.99 | $1.76 | IP68, Silicone filled, Rainbow Ribbon | |
Matrix | WS2801 | 42 pixels (0.15x0.18m) | 12vdc | xx | xx | link | $35.00 | $0.83 | Not Waterproof, Rainbow Matrix |
Stellascapes
String (Stella-green) | SS-1 | 85 pixels | 5vdc | 10 | 10 | link | $168 | $1.98 | bullet or flat packages | |
String (Stella-black) | SS-1 | 85 pixels | 5vdc | 10 | 10 | link | $240 | $2.82 | bullet or flat packages | |
Strip (Stella-black) | SS-1 | 85 pixels | 5vdc | link | 45 or 90mm pitch |
DIYLEDEXPRESS
String | None | 50 nodes (5m) | 5vdc | 10 | 0 | link | IP68 | |
String | None | 50 nodes (5m) | 12vdc | 10 | 0 | link | IP68 | |
Strip | None | 5m | 12vdc | 30 | 0 | link | IP65, can be cut every 3 LEDs | |
Strip | None | 5m | 12vdc | 60 | 0 | link | IP65, can be cut every 3 LEDs | |
Module (rectangular) | None | 20 nodes | 12vdc | 30 | 0 | link | IP66 |
HolidayCoro
String | None | 50 nodes (5m) | 12vdc | 10 | 0 | link | ||
Strip | None | 5m | 12vdc | 30 | 0 | link | silicone tube and coating | |
Module (rectangular) | None | 20 nodes | 12vdc | 10 | 0 | link | 3 LEDs | |
Module (square) | None | 20 nodes | 12vdc | 10 | 0 | link | 3 LEDs |
Ray Wu
(China Based)
String | None | 100 nodes (10m) | 12vdc | 10 | 0 | link | IP68 | |
Strip | None | 5m | 12vdc | 30 | 0 | link | silicone tube | |
Strip | None | 5m | 12vdc | 30 | 0 | link | IP68,silicone coating | |
Strip | None | 5m | 12vdc | 30 | 0 | link | IP68,silicone tube and coating | |
Strip | None | 5m | 12vdc | 30 | 0 | link | epoxy coating | |
Strip | None | 5m | 12vdc | 60 | 0 | link | silicone tube | |
Strip | None | 5m | 12vdc | 60 | 0 | link | IP68,silicone tube and coating | |
Strip | None | 5m | 12vdc | 60 | 0 | link | epoxy coating | |
Module (rectangular) | None | 20 nodes | 12vdc | 10 | 0 | link | IP65, 2 LEDs | |
Module (rectangular) | None | 20 nodes | 12vdc | 10 | 0 | link | IP66, 3 LEDs | |
Module (square) | None | 20 nodes | 12vdc | 10 | 0 | link | IP68, 3 LEDs | |
Module (square) | None | 20 nodes | 12vdc | 10 | 0 | link | IP67, 4 LEDs |
String (square) | None | 50 nodes (10m) | 12vdc | 5 | 0 | link | IP68, RGB C7 lens | |
String (square) | None | 50 nodes (10m) | 12vdc | 5 | 0 | link | IP68, RGB C9 lens | |
Strip | None | 5m | 12vdc | 30 | 0 | link | IP68, Silicone filled |
