Advanced Channel Management
This is based on version 11V.
This portion of the manual is under heavy development.
![](/wiki/images/thumb/5/5e/Channel-Manager-lft.png/600px-Channel-Manager-lft.png)
- Channel: This is the numeric value of the channel. These are used when the sequence is sent to controlling hardware.
- Order: This field is used to adjust the order of the channels.
- Multiple DMX Group: A normal DMX universe has 512 channels. This is active when using hardware that allows 4096 channels per universe.
Advanced Renaming Channels
![](/wiki/images/thumb/e/ec/HLS_ChannelManager_RenamingSingleChannels_11V.png/300px-HLS_ChannelManager_RenamingSingleChannels_11V.png)
- When done, Click Save All Channels.
Reordering and Renumbering Channels
Using Folders
![](/wiki/images/thumb/7/7b/HLS_FolderName_11V.png/300px-HLS_FolderName_11V.png)
Create a New Folder:
- Click the Add Folder button on the top toolbar. (See Figure 3-12).
- A dialog box will open asking for a Folder name. Type name and press OK. (Se Figure 3-13).
- Once entered, the folder will appear at the top of the list of channels and have ++ on the left-most square to identify it as a folder. (See Figure 3-14).
![](/wiki/images/3/33/HLS_ChannelManager_Folder_11V.png)
Copying Channels
Revisions needed.
2013-01-21 Confirmed the following works exactly as stated on version 11V.
To copy one or more channels click on the channel and asterisks will appear to the left of the channel name (see Figure 1-20). The click again on the channel to select it. Then Select the Manage Channels tab and choose Copy - Paste Whole Channels. You will then be prompted to Click on the Channel to Paste To.
To copy multiple channels click on the first channel to be copied and asterisks will appear to the left of the channel name. The without clicking move your mouse down to include all of the channels you would like to copy (see Figure 1-21). Asterisks will appear to the left of the channel to be copied. Once you have selected all of the channels to be copied click again on the last channel to be copied to select all of them.
Figure 1-21
Deleting Channels
Program Help File
Paste help file from HLS channel manager here.
Setting up HLS Channels | Chapter 3: Channel Management | RGB Channels |
