RGB Channels
This page is in process of being revised.
Introduction to RGB
Adding RGB Channels
3 to 1 channel conversion process.
Channel Reduction
RGB can also be used to program non-RGB lights to reduce the number of channels by 2/3. For example, imagine a Mega tree with 16 strings red, white and blue lights (48 strings total). Each RGB channel could represent 3 outputs, red, white, and blue. When programming, if red is chosen for the effect the red lights would be on. When green is chosen for the effect the white string would be on, when Blue is chosen blue would be on. If white is chosen for the effect color, all three would be on.
[[Advanced Channel Management] | Chapter 3: Channel Management | Configuring Display Groups |
